Fri, Jan 10, 5:53 AM CST
Forum Moderators: Staff
Subject: help needed for attaching body parts
Daramski ( ) posted Tue, 30 May 2000 at 10:09 PM · edited Fri, 10 January 2025 at 12:55 AM
I have been working on converting a 3d model of a bug from bugs life into a poser figure, so far I have loaded each body part in seperatly and have linked them to the appropriate body parts, I am having a job attaching some parts mainly the left side for some reason, but what my main problem, is that when I try and move a part, it easily tears itself away from the body, do I need to set up IK chains, if so how do I? If this makes any kind of sense could you please give me some advice, as I am still fairly new, any help will be appreciated. T.I.A cheers, Darren
wyrwulf ( ) posted Tue, 30 May 2000 at 10:38 PM
Check the tutorial at ThorneWorks. It is easy to follow, and explains the basics very well. http://www.thorneworks.com/
Daramski ( ) posted Wed, 31 May 2000 at 8:30 PM
thanks for the tip mate, I will check it out.
NightMask ( ) posted Fri, 02 June 2000 at 5:44 PM
Check out the advanced tech guide on www.curiouslabs.com site too
Daramski ( ) posted Fri, 02 June 2000 at 9:27 PM
Hey thanks mate, I grabbed the comic bunny also, Ideal, that should give me some more to read up on : )
