Thu, Nov 28, 4:39 PM CST
Subject: Tailor update
pdxjims ( ) posted Fri, 02 May 2003 at 5:09 PM · edited Thu, 28 November 2024 at 4:36 PM
Just got my newsletter from Daz, and there's a Tailor update to version 1.5. It's importing P5 characters just fine now. Some other nice new features too. Pretty neat! Thanks CodeTwister!
dialyn ( ) posted Fri, 02 May 2003 at 5:11 PM
Thanks for the head's up. I'm afraid I discarded by newsletter without reading it very thoroughly....bad on me!!!
milamber42 ( ) posted Fri, 02 May 2003 at 5:40 PM
Thanks for the info!
FishNose ( ) posted Fri, 02 May 2003 at 5:43 PM
Yahoooo! Thanks for info! :] Fish
Mazak ( ) posted Fri, 02 May 2003 at 6:01 PM
Thank you for this info! :) Mazak
Google+ Bodo Nittel
milamber42 ( ) posted Fri, 02 May 2003 at 6:02 PM
I just downloaded it and CodeTwister added a batch processing mode for morphs. I have not used it yet, but it looks like you can set up a list of FBM's to be processed and then just turn Tailor loose,
dlfurman ( ) posted Fri, 02 May 2003 at 6:15 PM
Yes, thanks for the heads up on this!
MeInOhio ( ) posted Fri, 02 May 2003 at 6:23 PM
So what's the install procedure? I just bought a new computer and I haven't installed my old version yet. I have the first version and then 1.1 and now 1.5. Could be remembering wrong, but I think you were suppose to uninstall 1.0 before installing 1.1 and that you had to edit the registry or something. Thanks.
Mazak ( ) posted Fri, 02 May 2003 at 6:26 PM
Here the new features, (snip) History of the releases V.1.5 1) Added compatibility with the files of Poser 5. 2) Added support for compressed files Crz. 3) Added a queue that allows the transfer of more selections of morphs in a batch mode without the subsequent user intervention. In the case of the transfer of more FBM, the information collected during the process of the first FBM are reutilized for the creation of the others, obtaining a significant improvement in speed. 4) Now supports FBM that are linked to morphs that are linked to other morphs. 5) Added a window for configuration 6) Now the characters can be viewed texturized 7) A new function helps to discover problems in the geometries 8) Removed the anomaly of clothes floating over the head (snip) Mazak
Google+ Bodo Nittel
JetM ( ) posted Fri, 02 May 2003 at 8:36 PM
Awesome!
SWAMP ( ) posted Fri, 02 May 2003 at 11:05 PM
I've DL the update three times,and this is what I keep getting.This isn't an exc. file..what is it? SWAMP
fretshredder ( ) posted Fri, 02 May 2003 at 11:09 PM
what folder is that in? I ask because the [1] at the end suggests that you copied it out of your temporary internet files folder (if you are on a windows machine). The file size looks correct to me. Perhaps you can just rename the file to end in .zip?
EricofSD ( ) posted Fri, 02 May 2003 at 11:11 PM
hmmm, closer, but I still can't get dresscoat italia to fit judy.
SWAMP ( ) posted Fri, 02 May 2003 at 11:17 PM
The folder it's in is My Doc...no copy,this is where I DL to.Did your DL as a zip file?Never seen Daz do that. SWAMP
pdxjims ( ) posted Fri, 02 May 2003 at 11:22 PM
Checnge the extension from nothing to .exe and it works just fine.
SWAMP ( ) posted Fri, 02 May 2003 at 11:38 PM
Thanks...that worked. SWAMP
Tashar59 ( ) posted Fri, 02 May 2003 at 11:52 PM
Just got my news letter too. First thing I read. I had tailor right from the start. Thanks for listing the features. All improvments are great. Off to go get it now.
fretshredder ( ) posted Sat, 03 May 2003 at 12:21 AM
err... DUH... yeah I meant to say change it to EXE not ZIP... pdxjims is correct =)
bikermouse ( ) posted Sat, 03 May 2003 at 12:51 AM
no newsletter yet - if you have the 1.1 version do you have to buy it again to get the 1.5 version?
SWAMP ( ) posted Sat, 03 May 2003 at 12:58 AM
Attached Link: http://store.daz3d.com/catalog/product.php?pcode=ps_ap025b
No...here is the link.Update is at the bottom SWAMP
bikermouse ( ) posted Sat, 03 May 2003 at 1:20 AM
DL'd it ok as an exe. Thanks SWAMP! - TJ
lalverson ( ) posted Sat, 03 May 2003 at 1:56 AM
I tell ya, the new support it gives is great and the batch loader is just sweet! and the whole process is real fast. I would say it halfs the normal time it takes to taylor a set to a custom body. I would say if you are thinking about getting it, get it, if you have it yupdate it and use the heck out of it.
pdxjims ( ) posted Sat, 03 May 2003 at 2:13 AM
Boy is it fast! Things that took me hours now take minutes, and the conforming is better. Batch mode works great!
fretshredder ( ) posted Sat, 03 May 2003 at 2:14 AM
I cannot tell you how happy I am that codetwister updated it to work directly with poser 5 .... well maybe I can .... I am happy about it =)
_dodger ( ) posted Sat, 03 May 2003 at 2:23 AM
goofy thing with Windows, instead of reading after the last dot for the extension, it reads after the first one. Generally it's a good idea when adding a version number to a file to include subversions with an underscore, like whatever_v5_05 or somethingoranother_6_006 or whatever, so this doesn't make windows trip.
compiler ( ) posted Sat, 03 May 2003 at 5:21 AM
Great update. Untill then I used to resave all my characters in Poser 4 before being able to Tailor their clothes. May be I will uninstall Poser 4, now... Thanks for the heads up. It seems I'm not the only one who discards newsletter after just browsing them...
Momcat ( ) posted Sat, 03 May 2003 at 9:45 AM
EricofSD: The Tailor can't make clothes created for one character fit another character. Not by itself anyway. There are a couple of mannikens available for V3 and Koshini, that will allow this to be done...sort of. They also require changing of joint parameters, which for these characters, there is a pose that will do that. Though in Koshini's case, I don't think the clothes will conform, but you have to use them as poseable clothing. With V3, the mesh is similar to V2 enough that it will conform. The only real way to get the clothing of one chgaracter to fit a completely different character would be to re-cut the obj file, and make a new clothing item.
c_hubert ( ) posted Tue, 06 May 2003 at 1:20 AM
Where do I find the Tailor? I looked in the daz store but could not locate it. Thanks
bikermouse ( ) posted Tue, 06 May 2003 at 1:39 AM
C_hubert, It's on the page Swamp provided in post #20. just click that link. - TJ p.s. As I forgot to say it on my original posts I'll take this opportunity to say thanks to Code Twister for the update! Thank you! Thank you! thank you!
yggdrasil ( ) posted Thu, 08 May 2003 at 7:28 AM
Went looking on DAZ but...
Update 4-29-03
Tailor 1.1 to 1.5 Upgrade
This update is unavailable for a short time. Please check back in a few hours.
  • Mark
Mark
Crescent ( ) posted Thu, 08 May 2003 at 10:13 AM
DAZ goofed and posted the Beta by accident. They said that they should have the finalized one available soon.
