Mon, Dec 2, 9:06 PM CST
Subject: SR3 post is English, German due next week
Curious_Labs ( ) posted Fri, 09 May 2003 at 11:12 PM ยท edited Sun, 01 December 2024 at 4:59 AM
Hi, I'm unable to change our server details so I wanted to post the information here. SR3 live this week is for the English OS - P5. I believe a mistake is listed on our server that states SR3 is for all P5 applications. If you are running a German version of P5, please use the SR3-G that will be posted (and announced) mid-next week. Kind regards, Katherine
EricofSD ( ) posted Sat, 10 May 2003 at 2:00 AM
So, when I pull down the file menu then slide the mouse to the right, the file menu stays down.
EricofSD ( ) posted Sat, 10 May 2003 at 2:02 AM
and here's the factory state, which really sux on 1024x768. I don't want the animation tool open all the time, or the paramater dial box half way off the screen that needs repositioning, or the work area all screwed up. Why can't it be like P4 or P5 basic through sr2.1?
EricofSD ( ) posted Sat, 10 May 2003 at 2:05 AM
and it won't correct itself when I set a preferred state. and what happened to the memory dots? They're gone.
EricofSD ( ) posted Sat, 10 May 2003 at 2:53 AM
and when I open a pz3 and decide to ditch it I have to click "don't save" twice. Guess it doesn't understand when I click it the first time. and when I open a pz3 that was previously saved, it moves the work space to the right and down half off the screen. Wasn't like that before. But I can say this, if I saved a pz3 of V3 with the morph injected, it opens in about 30 seconds with the morphs, as opposed to loading the model and locking up on injection. Guess its a good thing I still have P4 on my system to get started with the pz3.
CDI ( ) posted Sat, 10 May 2003 at 4:14 AM
And on the opposite end of the spectrum. I have none of the problems listed above. Granted the initial boot of SR3 seems slightly slower than the SR2.1. But after that the subsequent boots are lightening fast. Loading files are noticably faster as well. Rendering times are visably improved aslo. shrug A nice patch CL. Looking forward to more. PS: My workspace was fine after the patch. As for the memory dots check your Window menu. Make sure theyre still checked and then move the document window around and make sure they arent behind it hiding.
SimonWM ( ) posted Sat, 10 May 2003 at 4:41 AM
I have all the problems listed by EricofSD too.
uli_k ( ) posted Mon, 12 May 2003 at 12:53 PM
EricofSD, SimonWM, is it OK for you to switch to 'Launch to previous state' for the Interface Preference in General Preferences? By doing that, and by deleting your non-default UI pref file (as described in the readme), the workspace will look much cleaner.
SimonWM ( ) posted Mon, 12 May 2003 at 1:09 PM
Thanks Uli_k, I figured that out yesterday. I was trying to get it to unclutter itself by going to factory default. Thank you.
