Mon, Jan 27, 8:23 AM CST
Subject: Ack. I used a Mehndi Elves MAT on Vicky, and her eyebrows are gone ;P
crystalleaf ( ) posted Wed, 14 May 2003 at 8:16 AM ยท edited Sun, 26 January 2025 at 5:46 PM
Hello y'all, this is probably a newbie question but I am a Poser newbie :) I've played around with it for a while, but only bought it a couple of weeks ago. Sooo .... I made a character using Vicky and accidently applied the woodelf archer blonde eyebrows on her. Where her eyebrows were, there are now two holes and I can't seem to get the brows back. I'd hate to create a new character and apply all the facial changes again, so can anyone maybe spare me this fate? ;) Thanks in advance!
Axe_Gaijin ( ) posted Wed, 14 May 2003 at 8:28 AM
Sounds like the "eyebrows" material got set to transparant. Vicky has two sets of eyebrows. "Eyebrows" wich should be set to the same colour and map as the head. And the "Upper eyebrows" which should either have a transmap aplied to them or set you can make them disapear with the "brows gone" morph. So check under your material settings, check what it says under eyebrows and set them up with the same settings as the head. I hope I was clear enough, otherwise I'm sure Little_Dragon will jump in here and explain.. :) Cheers, Axe.
crystalleaf ( ) posted Wed, 14 May 2003 at 8:36 AM
Thanks for your hint, Axe... I had checked that, but a little detail slipped my mind .... I had a transmap setting which was wrong! Poor Vicky got her eyebrows back now... thanks! LOL! :D
Puntomaus ( ) posted Wed, 14 May 2003 at 3:27 PM
Isn't the Woodelf a character for Mike? You cannot exchange textures between Mike and Vicky, they are mapped different and the textures won't work.
