Fri, Jan 10, 10:18 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 10 10:15 am)
Carrara Free Stuff here.
Subject: What can you do with a .ai file in the spline modeller?
archlite ( ) posted Wed, 07 June 2000 at 10:15 PM · edited Fri, 10 January 2025 at 10:11 AM
I see taht you can import .ai and .eds files in the spline modeller in Carrara but what can you do with it. If I have say a wing in .ai would the spline trace that wing into a mesh or am I way off track on the function of that import?
"But I being poor, have only my dreams. I place my dreams at your feet. Tread softly, because you tread on my dreams." --William Yeats
willf ( ) posted Wed, 07 June 2000 at 11:07 PM
The spline modeler describes shapes in a vector based format, much like an eps file. The mesh modeler is a data base of x,y,z points in space. You can translate from spline to mesh but not vice/versa. The spline model is a smaller file, is scaleable and better for curvred (or organic) sahpes. You can import your wing drawing for the basic shape and play with the envelope descriptions for curves etc, it takes some time to get the "feel" of it. Best thing to do is re-read the manual on the spline modeler & then open up some of the models that are on the CD, ungroup them and "jump-in" on the elements to see how they were made.
archlite ( ) posted Thu, 08 June 2000 at 12:25 AM
Thanks I'll go do that I was really confused when reading about the .ai files and needed some clarity. Thanks.
MarkBremmer ( ) posted Thu, 08 June 2000 at 6:26 AM
b07.jpg Hi Archlite, I use the spline modeler for super exact control of shapes. When creating the objects above, I draw the Cross Section paths in Illustrator. I then also draw the Sweep Path. So for each 3-d shape, I import 2 Illustrator files. I can get precise mathmatical control over paths in a way that I can't with Carrara's drawing tools. If you go to the Free Stuff section and dowload the Wheel/torus file you can see that I 'freehand' drew the Rim and Tire portions of the file but the tread had to be perfect or you would notice it in the image. That was a job for Illustrator. Then I could import the path. Mark
MarkBremmer ( ) posted Thu, 08 June 2000 at 6:32 AM
Ooops, When I said Sweep Path (although you can import that too), I meant Cross Section and Envelope.
archlite ( ) posted Thu, 08 June 2000 at 7:57 AM
Hey man thanks, that helped out a lot.
