Tue, Nov 26, 2:30 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: More about ERC slave code: Creating parabolic curves
VK ( ) posted Tue, 13 May 2003 at 3:26 PM · edited Mon, 25 November 2024 at 11:50 PM
The "valueOpTimes" operator in ERC slave code can be used to easily create parabolic-like (curved) tran dials. The curved movement consists of 2 components, for example the xtran and the ytran channels of the example prop "ball_1". One of the channels is the master (xtran, in this example), the other one the slave (ytran). The ERC slave code is a combination of the "valueOpDeltaAdd" and "valueOpTimes" operators. The ytran slave channel looks like this: translateY ytran { name GetStringRes(1028,13) etc... interpStyleLocked 0 valueOpDeltaAdd _NO_FIG_ ball_1 xtdriver deltaAddDelta 1.000000 valueOpTimes _NO_FIG_ ball_1 xtran } Note that the "valueOpDelta" operator comes first, followed by the "valueOpTimes" operator. At runtime, the ytran slave is first affected by valueOpDeltaAdd, which moves ytran to a non-zero value. Then, the new non-zero ytran is affected by valueOpTimes, which moves ytran to ytran * xtran. You can use the deltaAddDelta in ytran, or the ytran dial, to adjust the curve. The two valueOps must be controlled by two separate master channels. Therefore, you need an extra valueParm channel, which is a slave of the xtran master, and a master of the ytran slave. In this example, the extra master channel is "xtdriver". In the ytran slave code, the "valueOpDeltaAdd" operator points at master "xtdriver", the "valueOpTimes" operator points at master "xtran". Channel "xtdriver" simply transmits the motion of the xtran master to the ytran slave, so that the valueOps in the ytran slave are controlled by two masters. The channel code looks like this: valueParm xtdriver { name driveXTran initValue 0 etc.... interpStyleLocked 0 valueOpDeltaAdd _NO_FIG_ ball_1 xtran deltaAddDelta 1.000000 }
VK ( ) posted Tue, 13 May 2003 at 3:32 PM
Attached Link: Cannon1 example (50 KB)
Here's a simple cannon model (50 KB). There is a "Fire" dial on body part "gun", to move the bullet on a parabolic-like curve. This is not a real ballistic movement, but it looks much better than a straight lateral movement. To control the range of the bullet, you can set the altitude of the gun, and adjust the width of the curve a little bit (there is an additional "Range" master dial to adjust the value of the ytran slave). You can also choose a higher or lower deltaAddDelta in the ytran slave, to create a narrow or wide curve. The cr2 includes some more channels, to move the bullet out of the gun, before the curve starts. The code is documented, so you can see what the channels do.
kim99 ( ) posted Fri, 16 May 2003 at 9:48 PM
Thank VK. It is important information. I enhanced CR2Builder02h06.
VK ( ) posted Sat, 17 May 2003 at 10:30 PM
Thanks for the information :)
VK ( ) posted Sat, 17 May 2003 at 10:34 PM
Here's an example of a circular motion made of the xtran & ytran channel. The code uses a simple approximation to calculate the squareroot of 1-x^2. It needs only 8 channels, and the resulting motion of xtran and ytran isn't a perfect semicircle. When the xtran channel is set between -1 and 1, the model moves along the x and y axes on a semicircle. Channels "mult" and "square" calculate x^2. There's a second "square2" channel for the x^4. Channel "num2" calculates 15x^2, "num1" the subtraction in the dividend. "div1" calculates x^4, "div2" 12x^2, and "div3" the sum in the disivor. The division is calculated in the ytran slave: translateX xtran ..........min -1 ..........max 1 valueParm mult ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 valueParm square ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 ..........valueOpTimes ....................mult valueParm square2 ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 ..........valueOpTimes ....................mult valueParm num1 ..........initValue 15 ....................k 0 15 ..........valueOpTimes ....................square valueParm num2 ..........initValue 16 ....................k 0 16 ..........valueOpMinus ....................num1 valueParm div1 ..........valueOpDeltaAdd ....................square ..........deltaAddDelta 1 ..........valueOpTimes ....................square2 valueParm div2 ..........initValue 12 ....................k 0 12 ..........valueOpTimes ....................square valueParm div3 ..........initValue 16 ....................k 0 16 ..........valueOpMinus ....................div2 ..........valueOpPlus ....................div1 translateY ytran ..........valueOpDeltaAdd ....................num2 ..........deltaAddDelta 1 ..........valueOpDivideBy ....................div3
lesbentley ( ) posted Sun, 18 May 2003 at 6:22 PM
Very impressive VK. Any one got an aspirin? :(
Ajax ( ) posted Sun, 18 May 2003 at 9:04 PM
This is looking great. I'm going to use Taylor series to set up the basic trig functions in a week or two. With degree 5 polynomial expansions, we should be able to get good approximations in the 0 to 90 degree range.
VK ( ) posted Mon, 19 May 2003 at 6:39 AM
Very clever, Ajax. I tried the above truncated continued fraction for sin(x). It's exactly the same as the Taylor series expansion with degree 7 for sin(x). The Taylor series expansions are easier to code, and maybe more efficient (less channels): translateX xtran ..........min -3.07 ..........max 3.07 valueParm mult ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 valueParm square ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 ..........valueOpTimes ....................mult valueParm plus42 ..........initValue 42 ....................k 0 42 ..........valueOpMinus ....................square valueParm 20sqrx ..........initValue 20 ....................k 0 20 ..........valueOpTimes ....................square valueParm 42div ..........valueOpDeltaAdd ....................20sqrx ..........deltaAddDelta 1 ..........valueOpDivideBy ....................plus42 valueParm plus20 ..........valueOpMinus ....................square ..........valueOpPlus ....................42div valueParm 6sqrx ..........initValue 6 ....................k 0 6 ..........valueOpTimes ....................square valueParm 6div ..........valueOpDeltaAdd ....................6sqrx ..........deltaAddDelta 1 ..........valueOpDivideBy ....................plus20 valueParm plus6 ..........initValue 6 ....................k 0 6 ..........valueOpMinus ....................square ..........valueOpPlus ....................6div valueParm 1sqrx ..........valueOpDeltaAdd ....................square ..........deltaAddDelta 1 ..........valueOpDivideBy ....................plus6 valueParm plus1 ..........initValue 1 ....................k 0 1 ..........valueOpPlus ....................1sqrx translateY ytran ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 ..........valueOpDivideBy ....................plus1
Ajax ( ) posted Mon, 19 May 2003 at 7:47 PM
That graph looks good. I'm a bit worried about the potential for divide by zero errors though, which is another advantage of Taylor series. Have you tried stacking the operators within a single channel? For example, is it possible to get a power by just putting multiple valueOpTimes lines in a single channel?
VK ( ) posted Tue, 20 May 2003 at 4:21 AM
Yes, it's a very good idea to consider the divide by zero problem. I didn't try multiple valueOpTimes in a channel, which could maybe work. The valueOpTimes & valueOpDivideBy combination seems to fail, but the valueOpPlus & valueOpMinus do work.
Ajax ( ) posted Mon, 09 June 2003 at 10:28 PM
These new operators, what are we going to call them? They're outside the bounds of ERC, which really refers specifically to the sytem Poser uses for the type of remote control seen in full body morphs. We could put another E on there for Extended but since the E in ERC already stands for Enhanced, that doesn't seem so good. My suggestions are either MORC (mathematical operator remote control) or, my preferred option, ARC (arithmetic remote control). What do guys think? Should we call this stuff ARC?
VK ( ) posted Tue, 10 June 2003 at 6:53 PM
Well, from the programer's point of view, valueOps are valueOps, whatever they eventually do (or don't do :). But a new word for the new valueOps is more user-friendly, I think. I vote for ARC (shorter, and MORC sounds like MAT & MOR stuff). BTW, I tried different implementations for the series expansion of sine. The first example is a degree 9 polynomial. The 1/3!, 1/5! etc. are solved to 8 decimals precision, and set as initialValue and "k" value in the "sn_exp" channels. The code is very compact (8 channels). Unfortunately, it creates a considerable error (ymax is at x=1.435, y=0.951): translateX xtran valueParm sn_xmult ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 valueParm sn_xsquare ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 ..........valueOpTimes ....................sn_xmult valueParm sn_exp3 ..........initValue 0.16666667 ....................k 0.16666667 ..........valueOpTimes ....................sn_xsquare ..........valueOpTimes ....................sn_xmult valueParm sn_exp5 ..........initValue 0.00833334 ....................k 0.00833334 ..........valueOpTimes ....................sn_exp3 ..........valueOpTimes ....................sn_xsquare valueParm sn_exp7 ..........initValue 0.00019841 ....................k 0.00019841 ..........valueOpTimes ....................sn_exp5 ..........valueOpTimes ....................sn_xsquare valueParm sn_exp9 ..........initValue 2.75e-06 ....................k 2.75e-06 ..........valueOpTimes ....................sn_exp7 ..........valueOpTimes ....................sn_xsquare translateY yTran ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 ..........valueOpMinus ....................sn_exp3 ..........valueOpPlus ....................sn_exp5 ..........valueOpMinus ....................sn_exp7 ..........valueOpPlus ....................sn_exp9 The second example is again the degree 9 expansion. The 3!, 5! etc. divisors are set as initValue and "k" value, and Poser calculates the quotients in extra "sn_div" channels. The "valueOpDivideInto" is secure in this case, since the divisor is a static value >0. The code needs 1 channel more per term (12 instead of 8), but it's very accurate (ymax at x=1.5708, y=1.000): translateX xtran valueParm sn_xmult ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 valueParm sn_xsquare ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 ..........valueOpTimes ....................sn_xmult valueParm sn_exp3 ..........valueOpDeltaAdd ....................sn_xsquare ..........deltaAddDelta 1 ..........valueOpTimes ....................sn_xmult valueParm sn_div3 ..........initValue 6 ....................k 6 ..........valueOpDivideInto ....................sn_exp3 valueParm sn_exp5 ..........valueOpDeltaAdd ....................sn_exp3 ..........deltaAddDelta 1 ..........valueOpTimes ....................sn_xsquare valueParm sn_div5 ..........initValue 120 ....................k 120 ..........valueOpDivideInto ....................sn_exp5 valueParm sn_exp7 ..........valueOpDeltaAdd ....................sn_exp5 ..........deltaAddDelta 1 ..........valueOpTimes ....................sn_xsquare valueParm sn_div7 ..........initValue 5040 ....................k 5040 ..........valueOpDivideInto ....................sn_exp7 valueParm sn_exp9 ..........valueOpDeltaAdd ....................sn_exp7 ..........deltaAddDelta 1 ..........valueOpTimes ....................sn_xsquare valueParm sn_div9 ..........initValue 362880 ....................k 362880 ..........valueOpDivideInto ....................sn_exp9 translateY yTran ..........valueOpDeltaAdd ....................xtran ..........deltaAddDelta 1 ..........valueOpMinus ....................sn_div3 ..........valueOpPlus ....................sn_div5 ..........valueOpMinus ....................sn_div7 ..........valueOpPlus ....................sn_div9
VK ( ) posted Tue, 10 June 2003 at 6:57 PM
Attached Link: Sine Prop (5KB)
I needed the exact values for this little sine-prop. The code uses the above formula to calculate sin(x) for -pi/2 < x < pi/2. The resulting motion is repeated 5 times, and the segments are linked, to create sin(x) for -5pi/2 < x < 5pi/2 (-7,8 to 7,8). There are "xDim" and "yDim" dials to adjust the amplitude, wavelength (positive values), and direction (negative values). Dial value 1 is 1 Poser unit. The prop can spin at place (standard rot dials), and there are extra "rotCurve" channels to change the orientation of the motion (rotate the "curve").
Allstereo ( ) posted Thu, 24 January 2013 at 9:01 AM
Attached Link: http://www.renderosity.com/mod/freestuff/details.php?item_id=70460
Hello all,
We are January 2013. After creating my ERC Trajectory Prop (to be found in the freestuff section, see the attached link), I discover this thread.  So, for those of you that reach this thread, you can also look at my freestuff. There is a detailed tutorial included with the package. You will see that I use also various operators and that the basic concept are quit similar to those of VK
Allstereo
