Mon, Jan 27, 3:05 PM CST
Photography F.A.Q (Last Updated: 2025 Jan 22 8:17 pm)
Subject: here's a challenge shot
caleb68 ( ) posted Thu, 22 May 2003 at 7:40 PM · edited Sun, 26 January 2025 at 8:11 PM
Not the best, but after i got home i sure wasn't gonna go hike back out there to retake the shot (6 miles) still trying to figure out this camera of mine.
Michelle A. ( ) posted Thu, 22 May 2003 at 7:50 PM
Hey Caleb....welcome to our little corner of 'rosity! Kewl entry!
I am, therefore I create.......
--- michelleamarante.com
caleb68 ( ) posted Thu, 22 May 2003 at 8:00 PM
thanks, took forever to find something that would be original.. its a grape vinard (sp) thats being started outside of town. Went hiking to go take some shots of the old damn up there but that got ruined by bad weather :(
cmarcant ( ) posted Thu, 22 May 2003 at 10:38 PM
I am not familiar with this forum and hang around in the 2D section instead. Are color corrections and retouching welcomed? I saw your picture and felt it would be good material to apply new skills I just read about. Let me know if is OK! Christophe
caleb68 ( ) posted Thu, 22 May 2003 at 10:54 PM
my photo? feel free christophe, lemme see when your done :)
cmarcant ( ) posted Thu, 22 May 2003 at 11:39 PM
Here it goes: I removed the purplish cast and increased the contrast a tad. If you have photoshop, I'll send you the file. I like the compostion. Christophe
caleb68 ( ) posted Fri, 23 May 2003 at 1:28 AM
wow wonderful :D looks great now :) how did you remove the purplish cast to it? the other i know how to do
Akire ( ) posted Fri, 23 May 2003 at 11:18 AM
I kinda liked it with the purpleish cast- it gave the impression of a very old photograph. The corrected image is great too, it draws your eyes down the rows and gives more of an impression of spring.
cmarcant ( ) posted Fri, 23 May 2003 at 12:06 PM
I am reading 'Photoshop Restoration & Retouchiing' by Katrin Eisman. It walks you through the different stages of image restoration in a very no-nonsense way. I first put 3 color samplers: the first one in the deep shadow of the thicket in the lower left corner, the 2nd on in one of the white tag highlights, and the 3rd in what I thought should be neutral n the dirt toward the upper right corner. I had actually used a threshold layer to figure out my best shadow and highlight locations, that I later discarded once the samplers where in place. I read the following RGB values: shadow: 38, 45, 36 neutral: 140, 123, 153 highlight: 216, 214, 253 Because all of those should be neutral, I needed to align the numbers using a curve layer following these guidelines: shadow to lowest number B 36 by decreasing R 38 and G 45 neutral to medium number R 140 by boosting G 123 and decreasing B 153 highlight to highest B 253 by increasing R 216 and G 214. I modified the curve on a channel by channel basis adding each time 3 points: red: 38,36 - 140,140 - 216,253 blue: 36,36 - 153,140 - 253,253 green: 45,36 - 123,140 - 214,253 This allowed me to get a color balanced picture. Because it was still a bit flat, I then added another curve layer in multiply mode where I pulled the RGB toward the upper left corner in order to lighten a bit the muliply effect (total question of personnal taste at this time ;-) unlike the color balance). Christophe
caleb68 ( ) posted Fri, 23 May 2003 at 12:23 PM
ah cool :) thanks for the tips christophe, got some other images that didn't turn out too good i'd like to try this with.
Michelle A. ( ) posted Fri, 23 May 2003 at 1:51 PM
Very interesting tip! Thanks for posting it! I'm sure others here will find it useful as well. :~)
mysnapz ( ) posted Fri, 23 May 2003 at 2:43 PM
Well, we have two images here so youve just got to compare them. The second is very straight Im not sure about the level of green looks like its been shot on Velvia. I personally like the original it has atmosphere and a cool feeling about it. :0 )
Those who do not want to imitate anything, produce nothing. Salvador Dali
starshuffler ( ) posted Fri, 23 May 2003 at 3:49 PM
Kewl entry, Caleb! And welcome to the forum! :-D wave wave The tip was kewl, too. Thanks, Christophe! (Welcome to the forum to you, too!) (*
JordyArt ( ) posted Fri, 23 May 2003 at 7:27 PM
I dunno, you turn your back for two seconds and things start getting technical ;) Welcome Caleb.....nice shot! (",)
caleb68 ( ) posted Fri, 23 May 2003 at 7:38 PM
thanky star n' jordy :) hopefully i'll figure all this stuff out and do some nice pictures like u guys n' gals :)
