Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Ok I tried something else, I created a new image V3, DAZ textures, simple lighting and the white shoes from the nightlife shoe collection - rendered fine at 1500 X 1500 and 150 dpi. Then I changed only the shoes to the black strappy ones(that I used before and couldn't render) and it refused to finish rendering. That is just odd as I've never had that type of issue before - and I've used these shoes as they are my favorites. So I tried to render another image that has given me problems and I've been unable to render - a barefoot image and it also refuses to render. I think it hates me :-/
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same
God who has endowed us with sense, reason, and intellect has
intended us to forgo their use.
-Galileo
I had that problem awhile ago with Stephanie and some of ISOP's stuff, nothing else created that problem with Stephanie but ISOP's items. I think it may be an issue of how your computer handles your memory, not harddrive space. Do you happen to be running Win98? Cause this occurred with Win98 but hasn't happened once since upgrading to XP? How much RAM do you have? Not sure this is the answer, but hope it helps.
WEll I don't know what the damned problem is but I;m starting to get really ticked off! I have 240 MB of RAM - should I add more memory? As for files I don't know if I have too many - what's the limit? I clear it out on a regular basis and it has it's own harddrive now. I frequently clear out items I rarely use and only install them when needed. But there are still a good number of items installed. Today I coudln't even render a 750 x 750 72 dpi image with a v3 wearing only the bottom to BAT's outfit, fairy wings and hair. It was the third in my bondage fae series and now I can't render it. This just began about a week - 2 weeks ago before that I always rendered at a minimum of 1500 and up to 3000. Now I can't do any size that is large enough to do adequate postwork on! I checked at CL but of course there is nothing tehre about rendering issues.
-Galileo
Attached Link: http://www.memturbo.com/
try doing your defrag and all that good stuff. I doubt it is the ram as I have 160 of ram {I cant do highres but I can do some mean renders sometimes BIG ones too as I usually go for 600+ and up as well as 200-900 dpi} but befor you start try going to cntrl+alt+dlt and be brutal with what you end task on leaving what is minimum for runing your sytem. see if that helps any. I have noticed that since I started using a demo or memturbo it HAS helped in that area. GUH I cant remember what thread that was in. anyway here is the link it defrags your mem also has a mem scrub that seems to help.https://www.darkelegance.co.uk/
I actually always end task on absolutly everything I can when I am preparing to render large images. The only thing available in the task box is Explorer. I have scanned disk, cleaned disk and defragged. - but am still having issues - it's insane really. I'll try that demo
-Galileo
the mem turbo reallly recovers ram it helped me with some renders recently I was surprised by it really. You may also try a window washer. it realllllllly cleans your HD. you can even "add bleach" which really scrubs your HD of anything that is not needed like internet temp files...and caches that helps abit too
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use.
-Galileo
