Fri, Nov 8, 3:06 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 12:39 am)
Subject: How do I save a CR2 and rename morphs?
AliasAngel ( ) posted Tue, 27 May 2003 at 3:33 AM · edited Fri, 08 November 2024 at 12:39 AM
Like the subject says, I'm wondering how to save my characters and all their morphs as a CR2. Also, how can you rename a morph? I have tons that stuff like "nose14" and "eyes15" and I think I need more specific names. Thanks.
TrekkieGrrrl ( ) posted Tue, 27 May 2003 at 3:42 AM
In the cr2, which can be opened by something like Notepad, you can change the names on the dials. Very easy. To save a character as a new cr2 simply save it to the Figures palette. (the "+" at the bottom)
Jaager ( ) posted Tue, 27 May 2003 at 4:09 AM
Each morph has two names (has a name in two places) The channel name - the first line - starts with targetGeom ___ The dial name - the third line - starts with name ___ When you apply or spawn a morph, the name you type goes into both. You can change the dial name - either in the parameters window, or with the Hierarchy editor. The channel name, which is what Poser uses and a pose file links to, can only be changed using a text editor. If the channel names are unique, there is no reason to alter them, you never see them. Poser 4 will not allow more than one morph in a group to have the same channel name. It erases all but one when you open the file. Poser 5 will add a _X to the end of the channel name if there is one there already with the same name.
