Thu, Dec 12, 8:59 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 3:30 am)
Subject: Poser 5 Memory Dot disappearance
Dore ( ) posted Thu, 29 May 2003 at 4:21 PM ยท edited Thu, 12 December 2024 at 8:20 AM
I find that the memory dots for pose, camera, & UI have disappeared from my Poser 5 user interface, and can't seem to get them back. The "Windows" pull down menu from the tool bar still shows the dots checked but they are AWOL. Any suggestions for recapture would be appreciated. Thanks.
Dave-So ( ) posted Thu, 29 May 2003 at 5:17 PM
Online Now!
there was a thread on this awhile back, but can't remember anyone having a fix, other than reinstalling. If you look, you'll probably find the dots in the cloth room, and perhaps in others as well. I tried to eck out the code..its XML, but couldn't really figure out where the memory dot stuff resides...there are references to it in the pref files and ui folder...I tried to change some stuff but with no luck. Hopefully someone with more skill can figure out how to get them back without reinstalling. I'm going to send a bug report to CL right now...should have done that before.
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
dirk5027 ( ) posted Fri, 30 May 2003 at 6:35 AM
this just happened to me also, i had to reinstall
uli_k ( ) posted Fri, 30 May 2003 at 3:54 PM
Hi Guys, I was posting something like this a couple days ago: Either: Choose 'Launch to preferred state' under Edit->General Prefs. If the problem persists, delete your non-default UI prefs in runtime/prefs and start Poser again. Or: Try to use 'Launch to factory state'. If you're on SR3, go to Runtime/Prefs and create a directory called 'English'. Move your default prefs to that directory. Deleting the non-defaults shouldn't be needed here. Let me know if any of this helps.
Dave-So ( ) posted Fri, 30 May 2003 at 6:12 PM
Online Now!
well I'll be a monkey kissing his uncle...it worked !!!! Thanks much :) uli Oh..I used the SR3 method...moved the defaults, then chose "launch to factory state" and all is back to normal.
Dore ( ) posted Fri, 30 May 2003 at 6:30 PM
Uli_k, Thanks, your solution worked for me to. I don't understand why, but it works!
