Sat, Feb 1, 9:04 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 6:51 am)
Subject: Is Victoria3 supposed to load in Poser 4.0.3?
Dore ( ) posted Wed, 04 June 2003 at 10:47 AM · edited Fri, 24 January 2025 at 10:25 AM
I thought I understood that DAZ V3 was supposed to be usable in the Poser 4.0.3 127 that I have. It won't do so in my copy, I get two error messages about it not finding and can't open blMilWom_v3.obj in RuntimeGeometriesDazPeople, followed by an out of memory error message, even though the file was duly installed by the DAZ installer exactly where the error message says it looked. I installed the same files in the same locations in my copy of Poser 5 and that loads and performs with V3 just fine. Is my P4 screwed up or is V3 not useable in that Poser version?
dialyn ( ) posted Wed, 04 June 2003 at 11:06 AM
Vicky 3 works better (for me) in Poser 4 than in Poser 5. I've not had your problem but I bet the answer will show up soon.
Dagon ( ) posted Wed, 04 June 2003 at 11:12 AM
Attached Link: http://arcana.daz3d.com/daztech/index.php?id=3
Missing OBJ -Out of Memory The solution is to delete the rsr file associated with the obj. It is a file made by poser everytime you open the model. Occasionally it creates a bad copy and needs to have it erased. It is located in the same folder as obj file. Once you delete the file Poser will create a new file and the model should open normally. Example: for the error "Cannot find the file blMilWom_v3.obj." Run a search on your computer for the file blMilWom_v3.rsr. Delete that file. Do not delete the file blMilWom_v3.obj. If you accidently delete the wrong file you can re-install the product to replace it.
impish ( ) posted Wed, 04 June 2003 at 11:12 AM
V3 works just fine in Poser 4.0.3 sounds like there is a corrupted RSR file hanging around. Go to the directory with blMilWom_v3.obj and remove the blMilWom_v3.rsr file. Then try loading V3 into poser again.
wheatpenny ( ) posted Wed, 04 June 2003 at 11:16 AM
Site Admin
I also use Poser version 4.0.3 127, and i have no problems at all with V3
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
SAMS3D ( ) posted Wed, 04 June 2003 at 11:52 AM
Yep that is it, it happened to me in Poser 4.0.3
Lyrra ( ) posted Wed, 04 June 2003 at 12:17 PM
try killing the rsr like Dagon suggested. I've had a bad one show up at installation, before I ever used the figure. Very annoying, but DAZ reminded me and they were right (I felt like such an idiot too sigh)
Dore ( ) posted Wed, 04 June 2003 at 12:56 PM
Thanks for the help guys, your solution worked like a charm!
