Mon, Dec 23, 6:43 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Subject: Need help with BFMW & BFW
Shayne ( ) posted Thu, 05 June 2003 at 10:15 PM ยท edited Mon, 23 December 2024 at 3:10 AM
I need help with BFMW & BFW figures posted my newt which was a repost for Arduino. I have converted scwHiResNudeWwGen.pcf file to scwHiResNudeWwGen.obj the file was based on femaleNudeHiP3.obj. I place new .obj in same folder I figured it would be the easiest way to find it. When I click on character nothing comes up. This is my first time using the Mover so not sure if I did it right or if there is something else I missed. I used ObjAction Mover 1.1 By Maz. I have been searching for more info but not finding it so if you can help or point me in the right direction it would help lots.
Desdemmonna ( ) posted Thu, 05 June 2003 at 10:41 PM
Runtime:Geometries:scw2:scwHiResNudeWwGen.obj is the path the .cr2 on BFW and BFMW... Try this-make a folder in the poser geometries named scw2 and stick object file in there, that should do the trick, or edit the .cr2 to point to the folder your currently using by opening it in a text editor like notepad and changing 'scw2' with name of folder obj is currently in. I have absolutely no experience in editing .cr2's so I can't help you there :(
Shayne ( ) posted Thu, 05 June 2003 at 10:46 PM
woooohoooooooooo thanks Desdemmonna that did the trick. I was dreading having to learn to edit .cr2. Have looked into before for MAT files but gave up. Thanks alot.
Desdemmonna ( ) posted Thu, 05 June 2003 at 10:49 PM
:) Glad it worked.
