Mon, Feb 3, 6:42 PM CST
Subject: motsuas blouse 4 koshini
WLC ( ) posted Fri, 06 June 2003 at 1:53 PM ยท edited Mon, 03 February 2025 at 4:37 PM
TRIED EVERY THING STILL DOES NOT WORK
Dagon ( ) posted Fri, 06 June 2003 at 2:35 PM
used Stuffit Expander to convert the file in a PC readable format... worked just fine
download the attached file.
rename it blouse.cr2
genny ( ) posted Fri, 06 June 2003 at 2:35 PM
OK...First you need to have "Stuff-It" on your computer. If you don't, I am sorry to say, that I don't know where you get it right now, but the file for the "blouse" is in a format that is somehow related to "Stuff-IT" rather than "zip". Once you have "Stuff-it" somewhere in your hard-drive, Open the file, manually, "KoshinischoolUniform" and go to the file that is giving you a head-ache..........Blouse.cr2BINfile, or something to that effect. Right click on that file, and go to....OPEN WITH, Aladdin Stuffit Expander and a new folder will appear where-ever you have directed your expander file to go and save. After getting that new file, which should be something like..............blouse cr2........copy it and put it into the runtime/library/folder where you have the other stuff that goes with the uniform. Hopefully, this will work for you, and I am sorry that I don't know how else to explain it.......but this is what worked for me. If you need more help.....you can write to me.......or better yet.....WHY hasn't someone contacted Motsura? (: Genny
genny ( ) posted Fri, 06 June 2003 at 2:37 PM
OH...sorry, I guess I should mention that I am using Windows XP....so this all may not work for everyone. Genny
Scathdebas ( ) posted Fri, 06 June 2003 at 10:14 PM
Can you email me the blouse you got to work? I did contact Mosura, but I don't think he understood what I was trying to say.
Dagon ( ) posted Sat, 07 June 2003 at 1:00 AM
Scathdebas,
Unfortunately Motsura speaks only Japanese
Anyway, download the attached file to post #2: 'message1276031.txt'
right click the link and save to your HD as 'blouse.cr2'
Hope it helps
-Dagon
