Fri, Nov 22, 10:47 PM CST
Subject: The trouble with Victoria's eyebrows
wscottart ( ) posted Sat, 07 June 2003 at 8:26 AM ยท edited Fri, 22 November 2024 at 6:49 PM
Having searched the datbase...Having played around with victoria for countless hours. I have worked myself into fustration. The materials list eyebrows, uppereyebrows, and another eyebrow. Endless combinations of texture maps transparencies etc. I seem to never be able to get rid of those ugly bushy brows. When I do get them gone I have worked so much I can't remember how the hell I achieved the effect even after studying the pz files. Does anybody have a file/ tutorial/anything that might lead to some clarity on this issue? Yeah the dial away the brow helps sometimes.
SamTherapy ( ) posted Sat, 07 June 2003 at 8:33 AM
You can set 'em to transparent if all else fails. Not many texture/trans maps are produced for them, but you could adapt an existing one.
wscottart ( ) posted Sat, 07 June 2003 at 8:37 AM
Thanks I just found the beginners tips. I guess its best to set the brows to begone. I was trying a transparency map I had made. Just could not get it to work. I guess I need to start with a really good texture map on the upperbrows and continue tweeking the trans.Fustrating! How appropriate... I guess therapy is what I was really seeking. Sorry for venting here ladies and gentlemen.
SamTherapy ( ) posted Sat, 07 June 2003 at 8:52 AM
Haha. We all use this place to vent from time to time. If Victoria's upper brows were set to transparent by default, I'm sure most people wouldn't give a monkey's about them. Stephanie's brows are set to transparent, and I can't recall anyone being annoyed by them.
melanie ( ) posted Sat, 07 June 2003 at 9:10 AM
Transparency settings: Eyebrows: No transparency Upper Eyebrows: Transparency Min & Max 100%, Transprency falloff 0% The third eyebrow setting doesn't do anything, you can ignore it. That should do it. Melanie
PeterWahoo ( ) posted Sat, 07 June 2003 at 12:07 PM
NO don't set eyebrows to be gone! That is the worst thing you can do, and it doesn't even stick!!! The setting can go away very easily. You need the proper texture settings.
PeterWahoo ( ) posted Sat, 07 June 2003 at 12:08 PM
Upper Eyebrows
