Hummm.... So far so good. When you made this in rhino did you use the grids to help you with the size and scale? It some how looks out of perportion(sp) I don't have one as a referance so I could be way off here: Maybe the base is to small? And the steam is to long? Just some thoughts.
You can't call it work if you love
it... Zen
Tambour
You should ask about Rhino stuff in the Rhino forum. I am there many times in a day. When you say resize do you mean in Bryce or Rhino?
it... Zen
Tambour
Did you use a profile curve and revolve or did you make circles and loft them to make the glass? I ask this because There are different ways to scale it. If you used a profile curve (the way I would do it) you can change the look by turning on coutrol points for the curve and then move each one to get the right profile.
it... Zen
Tambour
