Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Attached Link: http://www.3dlapidary.com/HTML/Models.htm
I beleive that 3D Lapidiary just posted a Poser ready gemstone model ... at the very least thay have very many gemstone models in various formats which can be modified. You might be on your own for materials, but most colored glass materials should work fairly well in most cases.Robin Miller, who created the Poser4 prop and textures, and donated them to 3D Lapidary, is (as time permits her) currently working on figuring out P5 gemstone material settings. As 'thgeisel' said, the main problem is the rendering engine in P5. I'm sure many P5 users will want to see the results!
Rosemary
3D Lapidary
I tried some of the 3D Lapidary stones in Poser 5. The .dxf versions load fine, but I had to convert them to .obj format and run them through UVMapper first before applying any refraction or reflection shader nodes.
http://www.renderosity.com/messages.ez?Form.ShowMessage=1265727
Ohh nice animation of the gem stone L.D. I was going to download it but decided against it because i want sure how well the DXF would work in P4 as well as what settings i should use. They were pretty temping though if you could get it to render nicely. Still looks like i am SOL for P4 though and i do not have Carrara. I do have anton's dimaond set i might try and see if i can use his settings on them .
Anyone know of any nice looking gemstones like diamonds, emeralds, etc that will work on P5? Or node settings to make a passable texture for one? I found some objects but I'm not getting anywhere making it look decent. Thanks.
