Mon, Feb 3, 9:30 PM CST
Subject: making this dress
Wynter ( ) posted Wed, 14 June 2000 at 11:02 PM ยท edited Mon, 03 February 2025 at 4:16 PM
Hi all, I'm working on this period dress (though I'm not sure which period it is :-). Anyhow, I followed Steve's tutorial on cr2 editing and was pretty happy when it conformed and moved, etc. However, after I conform it, it does this breaking up thing at the bottom, which is noticeable from the side view. Has anyone else had this problem? This is definitely a WIP, more work needs to be done on shaping it to my satisfaction. Especially the sleeves, ugh. Any help would be appreciated. Thanks.
Lorraine ( ) posted Wed, 14 June 2000 at 11:13 PM
That looks pretty good. Hope you share it when you are done.
kyrin ( ) posted Wed, 14 June 2000 at 11:26 PM
I had this same problem with a figure and they posted the answer in there. I think maybe either putting in a center panel or joint parameters would fix this? Kyrin
Wynter ( ) posted Wed, 14 June 2000 at 11:43 PM
Yes, I will definitely share it when I get it looking right and working right. And one will be able to use it for personal use and commercial use (without contacting me :-) Kyrin, I appreciate the answer, but I wish I knew what you just said. This making of clothing thing is new to me. Also, another question for anyone who wishes to answer, and I know its been asked a 1000 times. This dress is made up of the formal gown and the sweater. How should I post it when its finished? Will there be some kind of copyright conflict if I post the object? Well, thanks for your answers and Kyrin, if you could give me a little more clarity, that would be great.
brainmuffin ( ) posted Thu, 15 June 2000 at 12:52 AM
It looks very nice. I think you have to add a WELD command in the cr2... Where did you find the cr2 tutorial, btw?
Wynter ( ) posted Thu, 15 June 2000 at 8:36 AM
The tutorial is from PoserWorld. http://www.poserworld.com/cr2%20tutorial.htm The "weld" command...? Ok, now I'm starting to get confused. Not an unusual place for me to be :)
brainmuffin ( ) posted Thu, 15 June 2000 at 1:58 PM
Wynter, Thanks for the tutorial link. Open up the cr2 in word, or wordpad. Go to edit, find, and type in weld. It'll bring yo to a whole long list of all the parts that are welded together. if your hip comes all the way down to the shins, like the formal dress, then I'd suggest opening up the formal dress.cr2 to see how zygote welded the shins to the hip. Hope this helps...
steveshanks ( ) posted Thu, 15 June 2000 at 3:52 PM
Did you use the Catsuit Cr2 I've had this problem since writing the tute you can either edit the JP's or try the trenchcoat cr2........if only the formal gown had long sleeves sigh!....Steve PS use objaction mover to encode the file for posting you'll find it in the free stuff
Wynter ( ) posted Thu, 15 June 2000 at 6:17 PM
oooh...Steve, you hit the nail on the head. See recent post, you'll figure out which one ;-) Thanks to all for their ready advice, much appreciated. Now, for a little refining and I'll post for all to share.
