Fri, Feb 14, 1:15 AM CST
Subject: Help with a Bryce question in French
dan whiteside ( ) posted Mon, 09 June 2003 at 7:36 AM · edited Fri, 14 February 2025 at 1:13 AM
Hi gang; Got this in my E-mail and ran it through BabelFish and I think he is asking if presets can be loaded as a group rather then one at a time: "Bonjour, j'essaye de comprendre par quel moyen je peux compresser (preset) une quantitde ciels ou autres sans devoir les importer un par un. Vers quel type de moyen dois-je rechercher. Un passionnde Bryce Merci Patrick." Is that what he's asking? And can someone help compose an answer in french? And is there a way to do what he asks? Thanks! Dan
TheBryster ( ) posted Mon, 09 June 2003 at 8:24 AM
I think the answer is: Non! (but that's only a guess)
Rayraz ( ) posted Mon, 09 June 2003 at 8:47 AM
As far as I know you can't import multiple files at the same time. A simple "Non" would sound kind of short though. Anyone here speaking more then 2 words french?
(_/)
Odyssey ( ) posted Mon, 09 June 2003 at 8:52 AM
Hello :o) That is exactly what he is asking :o) How can I put several skies or other materials into one preset :o) I don't have the answer for this, but if you have it, I will be glad to compose the answer in french for you :o) I am a very new brycer, but I recently bought one of Jonathan Allen's package and it contains one .bsk file with 25 skies in it..... so it's possible :o) Elaine
Rayraz ( ) posted Mon, 09 June 2003 at 9:01 AM
Oh, he want's to export multiple sky's or objects to one BSK or OBP-file? To do that hold the shift-key while clicking on the icons of the object you want to put in the file. That way you can select multiple sky's or objects. Then you use the same method of exporting as usual. You can't import several OBP or BSK-files though (as far as I know)
(_/)
Odyssey ( ) posted Mon, 09 June 2003 at 9:08 AM
Okay :o) Here it is in french : Dans le fenre des ciels ou autres, tenir la touche 'shift' enfonc et cliquer sur les icones des ciels ou autres qu'on veut archiver. Ensuite cliquer sur exporter et tous ceux qu'on a choisi se retrouve dans un seul ficher. Thanks for the tip :o) Elaine
Rayraz ( ) posted Mon, 09 June 2003 at 9:14 AM
Thanx for translating to french.
(_/)
dan whiteside ( ) posted Mon, 09 June 2003 at 7:20 PM
Thanks! I thought we has some French speakers here. and I'm sure Patrick thanks you as well.
holyforest ( ) posted Sat, 19 July 2003 at 8:48 AM
Attached Link: http://www.rendez-vous3d.com/
vaut le coup de poser la question dans le forum Bryce
Holyforest,
Hundreds of shaders for Carrara
