Mon, Nov 25, 12:06 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: Multiple suns in Vue4?
davidgreensmith ( ) posted Thu, 05 June 2003 at 9:27 AM · edited Mon, 25 November 2024 at 11:51 AM
Does anyone know if it is possible to produce multiple suns in Vue 4? For example, a landscape of a planet orbiting a binary.
sittingblue ( ) posted Thu, 05 June 2003 at 11:26 AM
Sure. Just experiment with lens flare to create the visibility of your light sources.
Charles
Charles
pmermino ( ) posted Thu, 05 June 2003 at 11:57 AM
Yes ... select your sun and duplicate it ... No ??
davidgreensmith ( ) posted Fri, 06 June 2003 at 2:28 PM
Thanks for the help. Now just need to work on it to get the desired effect.
gebe ( ) posted Mon, 09 June 2003 at 7:01 AM
For multiple suns I would use volumetric spotlights. Make them all shadowless, except the sun.
Guitta
sittingblue ( ) posted Mon, 09 June 2003 at 2:16 PM
Guitta,
By 'volumetric' you mean a volume atmosphere, right? The results look great.
Charles :)
Charles
gebe ( ) posted Mon, 09 June 2003 at 2:19 PM
No, I mean a volumetric light (spot or sun)
gebe ( ) posted Mon, 09 June 2003 at 2:22 PM
Volumetric light can also be in a NON volumetric atmosphere :-)
sittingblue ( ) posted Mon, 09 June 2003 at 2:40 PM
The reason I asked was because the image above doesn't show the volume option turned on. - Charles
Charles
gebe ( ) posted Mon, 09 June 2003 at 2:45 PM
Of course it did Charles :-)
sittingblue ( ) posted Mon, 09 June 2003 at 2:49 PM
Hun, I know you're tired from your long trip, but that the lens flare. ;)
Charles
gebe ( ) posted Mon, 09 June 2003 at 2:49 PM
OK, I understand. Lens flare. That's what I meaned. You also can make it volumetric then :-)
