Tue, Nov 26, 6:41 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 26 6:17 am)
Subject: Problem that I don't know what to call it.
eelie ( ) posted Mon, 09 June 2003 at 7:06 PM ยท edited Tue, 26 November 2024 at 6:39 AM
I've seen this discussed in the past but I can't remember what was given as a solution and I can't find any of the threads now - mostly because I'm not sure what to call this. I've got a picture that I've deleted things from but the nanoview and new renders still show the deleted items in camera mode. If I switch to director mode, they're gone but when I switch back they're there again. I've clicked everything I can think of to click and have closed and restarted Bryce but it's still doing it. What's the magic trick to fix this? Anybody? Please?!?! :o)
RodsArt ( ) posted Mon, 09 June 2003 at 7:44 PM
hold the ALT key and click on the window, works on all the preview windows.
___
Ockham's razor- It's that simple
eelie ( ) posted Mon, 09 June 2003 at 8:31 PM
I've tried that and it doesn't seem to do anything. I still have the old image there. :o( Any other suggestions?
RodsArt ( ) posted Mon, 09 June 2003 at 8:48 PM
try changing between wireframe,full rendering,& fast preview? maybe the rewrite will correct it.
___
eelie ( ) posted Mon, 09 June 2003 at 9:58 PM
I've tried all the types of render. When I read that last, I thought that sounded familiar, that someone had said before that doing the fast render would do it. Sadly, it didn't. I've even rebooted hoping it was some funky memory thing. It probably is but that didn't fix it. :o( Next idea? I really don't want to scrap what I've done and start over. ~starting to sniffle~
RodsArt ( ) posted Mon, 09 June 2003 at 10:56 PM
What if you make a new file, name it something different, close it. Open the trouble file, merge it into the new blank one, the original will bring it's objects, sky, everything, hopefully with exception of the glich.
___
eelie ( ) posted Tue, 10 June 2003 at 9:11 AM
:oD We are thinking alike! I tried that too but it didn't carry the sky over. That's what I'm trying to save at this point. I've tweaked and nudged on that silly sky and I'd rather not trash it. When I merged the trouble file into a new one, the sky in the new file was what stayed. I think I'm going to start growling now. :o)
Incarnadine ( ) posted Tue, 10 June 2003 at 11:37 AM
can you save your sky in the presets library?
ringbearer ( ) posted Tue, 10 June 2003 at 11:53 AM
Click on alt (for windows) when you select your scene to merge and it will bring in just the sky. It's a bit confusing because nothing changes in the scene, but if you click your memory dot for the skies, then your imported sky will show up there. Arleen
There are a lot of things worse than dying, being afraid all the time would be one.
eelie ( ) posted Tue, 10 June 2003 at 1:23 PM
I never thought about saving the sky as a preset. That might do the trick. If that doesn't work, I'll try your suggestion too Arleen. Thanks muchly! :o) Susan
