Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Well I just opened the one from Daz in photoshop and painted them thicker and longer, then saved it as a gray scale mode, then used it instead of the normal one. Guess it wouldn't be that hard to do it with the eyebrows too. If you need more help just email me. I'm new to poser but at least I got the eyelashes worked out I think. Love Esther
I aim to update it about once a month. Oh, and it's free!
Attached Link: http://www.big-i.com
If you are a member of www.Big-i.com, I have a free Vic3 texture in the freestuff called Strawberry Myst. I believe I have both brow and lash transmaps in there, but they ain't the greatest ;o). You may not be able to use the morphs if you don't have the V3 male pack, but you can use the tex on any figure (has no tex for the teeth and gums tho). If you aren't a member, you'll have to sign up to get the freestuff. Hope that helps a little. LaurieThanks, guys... Unfortunately, I haven't got the money to buy Daz's Textures... I did find someone's V3 Character that had some pretty good ones, I just wasn't sure if it had them before I DL'd it. On a Dial-up, a 6+ MB DL on the "Chance" of it having Brow Transmaps is a little hard to take. As far as www.Big-i.com, I'll have to check it out. Thanks again! TTFN
Well, I've just totally shot my budget on V3! Between V3, Head and Body Morphs, and Arduino's V3WWG, I'm too broke to buy the textures. The ones that came with Arduino, are fine (if a little bit sunburnt) but lack two things. 1- a high visibility Eylash Transmap that'll let the Lashes be visible in anything farther than a close-up, and 2- ANY sort of Eyebrow Transmap. The Painted on eyebrows are fine, but as usual when the texture maker does this, I'm stuck with the artists color choice (brown in this case.) Can anyone point me to a good translash/transbrow file so that My poor V3 doesn't look like the victim of some vicious prank? (It was posette, I tell you. She's absolutely green with envy!)
