Fri, Jan 10, 4:21 PM CST
Forum Moderators: Staff
Subject: Error message problem
Avengia ( ) posted Tue, 10 June 2003 at 8:47 PM · edited Fri, 10 January 2025 at 1:42 PM
Lately, I have been having a really weird problem, that maybe someone here can help me with. Whenever I have an error, I get the error message box, but I can't see any of the text on the inside. So, I have no idea what exactly the error is, so I can't change what it is that I am trying to do in the first place.
Also, there is one error message that I can see, and I have been getting it a lot. I have been getting a message that says: Can't read Runtime / Geometries/ "insert object name here"....then I get two empty error boxes, and the figure that I was working on disappears. I am going nuts, because I have to keep restarting. I even deleted Poser completely off my computer, and reloaded everything, and I am still having both problems. Any suggestions? Please?
-Signed..."Going Batty"
cruzan ( ) posted Thu, 12 June 2003 at 9:48 AM
well, not sure about the 1st problem - your os/poser version/hardware/etc may help on that one. In Poser the 3d obj file needs to be in the file directory and exact name that your library item is calling. If it is a daz product than it would have the 3d obj in the proper file with its installation. If it is a zip download of a 3d item than you must do one of 2 things: unzip the geometries to the exact name of the runtimegeometriesfilefoldername*.obj OR edit the cr2 that is your library in the 2 places you find runtime:geometries:*.obj to where you have placed the 3d obj file If you dont own the 3d item and are using an add on for a specific figure than you need to go buy the original specific figure for it to work. If you own the item and the geometries folder contains the proper obj file - could be the rsr that is in that geometries folder [in which case delete it] or you may need to (if windows user) scan/defrag disk.
Avengia ( ) posted Thu, 12 June 2003 at 12:28 PM
Thanks so much.....the other day I finally got so irratated with everything that I deleted Poser, and reinstalled everything. I was using PInstaller to install all of my zip files....and it was putting them all in the wrong spot. So, I sat down, went through one of the tutorials someone mentioned on this boards about where Poser files go and put all my stuff in their spots by hand! Now, everything works...lol. As for the error messages...grrrrr.....still can't figure this one out....lol.
