Tue, Feb 25, 12:38 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2025 Feb 23 2:34 pm)
Subject: Help
seaturtle ( ) posted Fri, 13 June 2003 at 11:35 AM · edited Tue, 25 February 2025 at 9:00 AM
O.k. here is the deal. I am makeing simple buildings in Lightwave. I mean simple. A small ledge, 4 side, and roof. Now when I save it as an .obj and bring it into Poser it becomes beveled. Any ideas. I need it crisp.
SAMS3D ( ) posted Fri, 13 June 2003 at 11:50 AM
Poser has a smoothing engine and rounds everything, two things you can do, either bevel your edges...all of them, or take and put your object into UV mapper and then click edit, tools, split verticies. Then save, all will be crisp, but your file will be alot larger. Don't save any normals. Sharen
