Thu, Jan 30, 8:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: Scaleing, and sensitivity Value
grid ( ) posted Tue, 17 June 2003 at 5:32 AM ยท edited Thu, 30 January 2025 at 7:58 AM
Hello and good day to all. After some Time making My Model animated in Poser,I think i finaly Have got it . The only thing i need now is 2 (?) answerd. When Scaleing the Parent of the model The rest of the model dose nothing. So i have to scale every thing manuly. is there a way to Edit the cr2 or Group them To all scale When the paernt scales? Second qustion ,Tracking sensitiviy value I have Tryed to change this many times but nothing seems to happen. I was thinking i have the Wrong name of this. If you know the name Of the sensitivity value in the cr2 please tell me. Thank you
lesbentley ( ) posted Tue, 17 June 2003 at 6:56 AM
If this is a cr2 then scaling the BODY actor should scale everything else. Also try this: Open the file in a text editor (or a cr2 editor such as CR2Builder) and search for any channels of the type "scale", if you find any replace the name with "propagatingScale". Do a similar procedure for the other scaling channels, change "scaleX" to "propagatingScaleX" etc. Note that the case of the "s" changes, these things are case sensitive.
lesbentley ( ) posted Tue, 17 June 2003 at 7:19 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1224978
To expand a bit on my last post, "propagatingScale" should force an actor or prop to scale with its parent, so: scale scale Would become; propagatingScale scale and; scaleX xScale Would become; propagatingScaleX xScale As for the "trackingScale" I have only ever been able to change this for "valueParm" channels. The thread linked above also relates to trackingScale issues.
grid ( ) posted Tue, 17 June 2003 at 5:38 PM
Thanx for the Help I will give this a try
