Fri, Jan 31, 3:31 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: poser python script HELP part 2
DarkElegance ( ) posted Tue, 17 June 2003 at 5:20 PM · edited Sat, 18 January 2025 at 6:24 PM
ok I reinstalled alll the things I needed to get pythons to work..YAY..got the light panel working YAY BUT I was reloading a script and it told me that in poser scripts that mainbutton.phy is locked I need to unlock it. ok so I went to it and clicked it.......nothing. not a thing. so I figured ok...Ill go and try to edit it....HA! nope. the IDLE wont open to do it...not that I would of known what really to do but....... HELLLLLLLPPPPPPPPP
https://www.darkelegance.co.uk/
Commission Closed till 2025
raven ( ) posted Wed, 18 June 2003 at 7:28 AM
If you change mainbutton.py properties from being read-only, you can apply changes to it then.
DarkElegance ( ) posted Wed, 18 June 2003 at 11:53 AM
ok I went in to its properties and unchecked the read only thing...and tried to click it...for a flash the black window poped open then was gone.... poser was not running at all.
DarkElegance ( ) posted Wed, 18 June 2003 at 12:09 PM
okI just did it again from the poser window and it gave me this odd error window which I have never seen beffooooooorrrr Tcl/Tk 8.0 aparently is not there or cant be found and the TK80.DLL and TCL80.dll are missing or what ever and I have nooooooo clue what they are.
