I've been killing myself trying to do this for years. Thanks Frogdot!
Thanks immensely. This is exactly what I need right now as I'm working on 2 scenes that need waves. Terrains are great for making ordinary at-sea waves, but this will give me those shoreline breakers that terrains just don't do well. Thank you Dankeschoen Merci beaucoup Mille grazie Muchas gracias Domo arigato gozaimasu Hsieh Hsieh Bahut dhanyavad Spasibo Shukran etc., etc. and so forth... :D
For wet sand, you can take your sand/beach terrain, duplicate it, then clip the bottom off just a bit. Give the the lower terrain a darker, shinier wet sand material.
Another way I've used, is postwork. Render the scene once with dry sand and a second time with wet sand, then layer them in your image editor and erase along the waterline, allowing the wet sand to show through
hope that helps.
Attached Link: original image
A few asked how it was done, so here's a mini-tutorial.
