I have had problems with a number of those morph injection packages. If I get too many of them injected at one time, the dials don't work. If I remove them and just inject the ones I actually want to work with, the dials then work. There is no error message but everything seems to stop and the menu bar is grayed out.
I onlly have one morph in, it works on her haed but not on her body. I have set the dials and everything. Like I said, the head works great. Her neck also works. When I choose 'body' I can onlly get one morph in, if I try for another, it only replaces the one I had. When I change the dials on the one under 'body' It does a whole bunch of nothing. I don't get why the dials would work for head and neck bot for nothing else... any ideas?
You need to get the Victoria 3 SR1.1 and the Male Morph Pack SR1.1 releases from DAZ. Those files update Victoria 3 and the Morph Packs. They have nothing to do with Curious Lab's patches for the Poser program. You can contact DAZ's customer service to get the updates, though you may be able to download them from somewhere in your account. (No guarantees that the V3 and MM updates are there, but it's worth a try.)
Not the SRs for Poser 5, there was an SR1 release for Victoria 3 from DAZ. Nothing to do with Curious Labs. The male morph pack doesn't work properly on V3 without the SR1. However, in poser 5 I've occasionally had the problem you described with V3 SR1, too. It seems to happen when I have more than one V3 in a scene. It shouldn't make any difference, but I think P5 is a little buggy with V3. My fix was to morph the characters I wanted, save to the library then start a new file and reload. That worked...but I guess if you can't inject the morphs properly in the first place that won't help for you.
