Photomodeler, which is competitive to the one that I use, RealViz ImageModeler, is for photogrammetry. These are very good for simple objects, but forget about organic forms. They're really only good for extracting textures from multi-view photos, but getting models out is not worth the trouble (unless you don't mind entering several thousand points correlated between the photos by hand). These do not do the modeling for you. You do the cross-referencing to establish 3D reference points and it extracts the texturing. Better to model in a real modeling program and use that model in either of these after making the 3D reference markers. BYS
I have used PhotomodellerLite and Geometra. There is a lot of technique involved. I will use a marker to place reference points directly on the model I am using, then take the photos from several angles. The results you can get depend upon the preparation. It IS possible to get a good model with photogrammetry. It takes practice and skill, the same as in any 3d modelling app. Organics are possible. Cars and trains are good subjects. I use kit-models. Try the free versions, as they are sufficient to get good results. Another approach is to make a quick and dirty photogrammetry model, then import it into a 3d modeller and use it as a reference, a 3d blueprint.
I'm curious if anyone has used this software & if does exactly what it says does. If it does, how good is the quality of the models it prepares??? Any thoughts would be helpful... TIA - Debby
