Mon, Feb 3, 1:00 PM CST
Subject: Yikes! Whats Going on with my V3 tush?
Daisybel ( ) posted Thu, 03 July 2003 at 7:53 PM ยท edited Mon, 03 February 2025 at 12:58 PM
The seam seperating the buttocks from the hip is all crumpled up. I was working on the front this standard V3 so I'm not sure what step produced this. Any tips (or plastic surgeons) to remove this "growth"? Thanks, Daisy
Daisybel ( ) posted Thu, 03 July 2003 at 7:57 PM
Don't know if this is related to my problem, but the wire frame is grayed out for the hip zone. Is this normal?
Wadus ( ) posted Thu, 03 July 2003 at 8:31 PM
I dotn use Poser very much so this may not be the case, but maybe you accidentally locked the hip and thats why its crumpled and the wires are grayed out...
Valandar ( ) posted Thu, 03 July 2003 at 8:35 PM
That sounds reasonable, but it still looks weird. ;-)
Remember, kids! Napalm is Nature's Toothpaste!
Dave71 ( ) posted Thu, 03 July 2003 at 8:51 PM
It looks to me like you have applied a morph to the butt areas and not the same corresponding morph to the hip area. You have to be careful when applying morphs that span across bodyparts, check to see if your morph has a Full Body Dial. Dave.
lhiannan ( ) posted Thu, 03 July 2003 at 8:51 PM
Do you have the V3 SR1.1 patch (I think that is the latest patch)? I know somewhere along the line they did something to fix scaling errors. Also, I checked my V3's wireframe and her hips and buttocks regions are the grey color and the rest black. Maybe something is actually wrong with the buttocks?
Lyrra ( ) posted Thu, 03 July 2003 at 9:11 PM
what were you doing? if you were making a morph via magnets you may have selects some back facets without meaning to ...
Daisybel ( ) posted Fri, 04 July 2003 at 7:58 AM
I was just using paremter dials to make changes. I will investigate the above tips (thanks all) to see if any work. Daisy
lesbentley ( ) posted Fri, 04 July 2003 at 8:04 AM
Daisybel, it's hard to work out what went wrong when we don't know what you were doing "working on the front" is not exactly informative. As Dave71 said, the most likley cause is that you only applied one morph out of what was meant to be a set of morphs. Help us to help you, and provide as much information as posible.
