Litterally combining them into one prop is not what you need. You can parent them all to one of them: Make sure you have a prop selected, in the figures menu select 'set figure parent...', find the prop you want to be parent in the drop down list, select it and voila: the parented prop will turn and spin with its parent when you turn or spin this. Proceed to parent all of the other items to that same parent, and then when you need you need to turn or spin your scene, you just turn or spin the parent and everything else turns with it. Was this what you had in mind? -Hanz
Hanz' idea is great and will work. Another way is to export all of it as an obj, then reimport that obj. The parts have then been kidan glued together. You can save the complete thing to your props palette but that is optional. Hanz' version will give you a model where you can still remove parts of it (for camera placements or the like) Whereas my version will be one coherent thing :o) Your choice :o)
