Wed, Nov 27, 10:34 AM CST
Subject: Sketch mode
---Gallego--- ( ) posted Mon, 07 July 2003 at 8:26 PM ยท edited Thu, 25 July 2024 at 7:25 PM
how can I render an image at 1550 x 2300 pixels in sketch mode??..can i?? poser 5 doesn't let me
wyrwulf ( ) posted Mon, 07 July 2003 at 8:29 PM
Make a one frame animation image file using sketch settings.
---Gallego--- ( ) posted Mon, 07 July 2003 at 8:49 PM
i don't understand...i'm sorry never animate nutin'
Spit ( ) posted Mon, 07 July 2003 at 9:40 PM
Poser by default sets itself up with 30 frames of animation. What you render when you're playing in Poser is actually frame 1. Once you have your sketch settings the way you want, here's how to render them larger: Go to Menu:Animation:Animation Setup Set the frame count to 1. Enter the Width and Height you want Okay out and answer Yes for Poser to delete the 29 extra frames. Next go to Menu:Animation:Make Movie Change the Sequence type to 'Image File' Set the Quality to 'Current Sketch Settings' Check the Antialias box Ignore the stuff on the right and click OK A Save dialog comes up. Select your image format and give it a name and tell Poser where to put it. Poser will add '0001' to the end of the name and render it to disk. When it's done it doesn't open in Poser, but it's there on your harddrive. HTH
