Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Jan 20 12:16 pm)
Well if you have DarkWhisper's Texture Converter it could be converted over to V2... I hadn't planned on doing a V2 version, but SOMEONE may be doing a make up add on pack for my Echo for V2 character/texture pack... so if you hint a lot then maybe said person will see the hint and do a similar style. :)
Attached Link: http://www.poserpros.com/store/viewitem.php?selitem=718
I'm having too much fun coming up with "out there" make up looks for Billie, so here's the second set! The Princess of Darkness, and The Princess of Light Set.Shown above is Dark Princess 1. There are two dark versions, and two light versions. The second version of each is a less extreme version of the first to make them more versatile.
I'm at work right now so if you want to see what the others look like you'll have to mosey on over to PoserPros and view the store promo renders.
This set, like the Seasons of the Witch set is part of PoserPros new ProClub, so it's available for only $2.49. But again, like with Seasons of the Witch, you will need Cin- Designs' Billie.
You could use these make up options with other V3 textures, but you may have to adjust them so that the skin tones will match.
