Sat, Nov 30, 11:34 PM CST
Subject: Problems with Poser 5 Renderer
kruse ( ) posted Tue, 08 July 2003 at 12:01 PM ยท edited Sat, 30 November 2024 at 11:29 PM
Hi All,
we need some advices. Our image shows a render in Poser 5, firefly (draft). We don't know how to remove this ugly brown stripes (see yellow marking). The mesh seems to be okay (here joint rButtock and hip), if we reduce transparency to zero, the stripes are gone.
Perhaps you can help us out, where to do the corrections (mesh? we use RDS or 3dmax or settings in Poser?)
Thanks a lot
Daniel + Matthias
wenke ( ) posted Tue, 08 July 2003 at 12:07 PM
Hallo ihr beiden, dass hat nichts vielmehr wenig mit dem Mesh zu tun, das passiert immer, wenn ihr wie hier, die Beine zu Seite posiert, dann erlappt sich das Mesh sozusagen, bekommt man nur mit Postwork weg.
3ncryptabl3_lick ( ) posted Tue, 08 July 2003 at 2:13 PM
remove backfacing maybe? shrug
kruse ( ) posted Tue, 08 July 2003 at 3:18 PM
Hi , backfacing? where can I find it? Matthias
3ncryptabl3_lick ( ) posted Tue, 08 July 2003 at 3:29 PM
that would be under render options... its a checkbox..
stewer ( ) posted Tue, 08 July 2003 at 4:03 PM
To verify wether it's a rendering or modeling problem, try it in r the Poser 4 renderer. If the problem still remains, it's probably a modeling/posing problem. If not, it is probably fixable with a few tunings in the render settings. You might want to try enabling polygon smoothing and playing with the material's transparency falloff and transparency edge settings. In order to get rid of the slight overlapping in at the left hip/upper thigh, you can add a very slight displacement to the clothing prop's displacement channel. This will lift the prop's polygons away from the figure just a tiny bit.
DominiqueB ( ) posted Tue, 08 July 2003 at 4:16 PM
Are these stocking mesh or only a texture? If they are mesh it is caused by the polygons folding one on top another when you are bending the leg. The only way to fix that IMHO would be to play with the blending zones.Eliminating those kind of problems are the most time consuming when you are creating garments. It may not be easy or even possible to completely eliminate this. Probably easier to correct this in postwork.
Dominique Digital Cats Media
kruse ( ) posted Wed, 09 July 2003 at 3:10 AM
Hi all, thank's for helping. We tried several settings in render options with the same results. Think it's an overlapping problem. These stockings are mesh and we are going to make some corrections in the bending zones. The Bryce or 3dmax renderer worked fine. Regards Daniel + Matthias
