Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 1:40 am)
The wonderbra morphs are available in the free stuff area.. Just do a search for Wonderbra you it will be there :) I don't know about the dress.. I might have one that could be used.. but I have to go through all my files.. but the leotard image could be transmapped and textured hope that helps Storm
You also MIGHT be able to do the hair by combining two (or more) existing models; a scaled up short hair (one of the default ones with Poser) should do for the "bee-hive" portion, while a black texture map on Burton's Strip Hair with the proper transparancies to split it into strands could work. You'd have to load one as hair and the other as an OBJ prop (or weld the two together separately as a single Hair prop) to do this, though.
