Sat, Jan 25, 9:28 AM CST
Subject: animation question
SVicious ( ) posted Thu, 10 July 2003 at 5:02 PM · edited Sat, 25 January 2025 at 9:09 AM
I have poser 5 and I am trying to work on a mvie but I find that once i am done with the movie the animation kind of looks a bit choppy is there a way to fix that. I render the movie in image files since I do a lot of post work on them.
onnetz ( ) posted Thu, 10 July 2003 at 5:35 PM
what fps are you using?
Handle every stressful situation like a dog.
If you can't eat it or play with it,
just pee on it and walk away. :-)
I wouldnt have to manage my anger
if people would manage their stupidity......
greenbd ( ) posted Thu, 10 July 2003 at 5:44 PM
What's the file size of your movie once you squeeze all the still images back into frames? Sometimes hi-res stuff can really bog down your video player. If you compress the finished video (Sorenson 3 and MPEG-4 are some of the best codecs for balancing quality and file size), that might help. Saving without using keyframes sometimes makes playback smoother, too.
TalleyJC ( ) posted Thu, 10 July 2003 at 9:34 PM
Like onnetz says... check your frame rate.... for simple web stuff you can get away with 12 or 15 fps... but not much slower. remember most video you see in film or tv is 24 or 30 fps.... if your movements are radical it will be jumpy.... if you have say a baseball player swinging a bat all the way around in only 5 frames, its going to look jerky
