Fri, Nov 29, 9:48 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Render to new Image: Saving?
Ralf61 ( ) posted Fri, 11 July 2003 at 4:21 PM · edited Fri, 29 November 2024 at 7:39 PM
Ok, savin' a rendered image works fine as long as it was not rendered to a new window. I can't find a solution to save this image in a new window. I read something, that it was impossible in Poser 4 - but is it now possible in Poser 5? Thanks for a quick info. Ralf
Ralf61 ( ) posted Sat, 12 July 2003 at 8:05 AM
Thx ockham, so I don't have to investigate further. Ralf
