Tue, Jan 21, 2:47 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: DAZ "INJection Pose Builder" problem
lynnJonathan ( ) posted Mon, 14 July 2003 at 6:05 AM ยท edited Tue, 03 December 2024 at 11:45 PM
Just bought it and was playing with it. Body morphs and Feature morphs seem to work fine but it ignores all the expression morphs. Like blink, open lips, and so on. Anyone know what the deal is? I tried on 2 different computers?
Momcat ( ) posted Mon, 14 July 2003 at 6:10 AM
Go to Options/Processing and uncheck the "Ignore Expressions" box.
^_^
LaurieA ( ) posted Mon, 14 July 2003 at 7:35 AM
Yep, play with the checkboxes in the Options. I believe it has Ignore All Expressions checked by default. You'll want to uncheck that :o) Laurie
rbtwhiz ( ) posted Mon, 14 July 2003 at 12:19 PM
Lynn,
Both responses above are correct.
To expand a bit... channels with an internal name of:
'Blink Left',
'Blink Right',
'BrowArchL',
'BrowArchR',
'BrowDownL',
'BrowDownR',
'BrowFrownL',
'BrowFrownR',
'BrowWorryL',
'BrowWorryR',
'Frown Left',
'Frown Right',
'Frown',
'LBrowUp',
'RBrowUp',
'Mouth A',
'Mouth CH',
'Mouth F',
'Mouth M',
'Mouth O',
'Mouth SH',
'Mouth TH',
'Mouth U',
'Tongue L',
'Tongue T',
'MouthDisgust',
'MouthSing',
'MouthSpeak',
'MouthYell',
'OpenLips',
'OpenLips2',
'OpenMouth',
'PartLips',
'Smile1',
'Smile2',
'SmileLeft',
'SmileOpen',
'SmileRight',
'Snarl',
'SnarlLeft',
'SnarlRight'
...are caught by the expression morph filter in IPB. By default, the option is set and the expression morphs are filtered out. Option dialogs are accessible from the Options menu or by using Hot keys. General [global] options, such as whether to include expression morphs or not, reside in the Options -> Processing dialog (F4). If you would like for this option to not be set by default, open the afore mentioned dialog, uncheck the option, and save your options (Options -> Save Options File). Saved in the options file, will be the state of all options (on | off) at the time you saved... along with the position (on screen) of all of the windows, the size of the main window (height / width) and the state (visible | hidden) of the option dialogs themselves. The saved options will be loaded each subsequent time you launch IPB. If after saving the options file, you ever want to revert to the default settings... you can 1.)Select Options -> Restore Default Options and then save again, or 2.)Simply delete the "IPBOptions.cfg" file located in the root folder of IPB.
-Rob (code monkey)
Spanki ( ) posted Mon, 14 July 2003 at 2:31 PM
Speaking of expressions, why are things like 'Eyewince' and 'NoseWrinkle' not considered expression morphs? (not just in this program, but by the various INJ and REM pose files as well).
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
MachineClaw ( ) posted Mon, 14 July 2003 at 3:03 PM
Attached Link: http://secure.daz3d.com/Update/ps_ap038-1_1update.exe
there is an update at Daz too. make sure ya got the newest. 6/10/03: Corrects 'shared library error' problems in Macintosh version of PoseBuilder ps_ap038-1_1update.sit /5/03: Adds Features Listed Below ps_ap038-1_1update.exe ps_ap038-1_1update.sit ** Hot Keys ** ** File IO ** Compare source for change prior to prompting for save ** General Options ** Read Options File Save Options File Default Options Restore ** Options File ** Record position of main window and option palettes Record size of main window; option palettes auto size Record option state for option palettes ** Processing ** Recursive Batch Processing Create INJ and REM Pose Simultaneously Create REM from INJ Pose Record Master Actors Only (BODY/head) Record Body Actor Only Record Head Actor Only Record Expressions Only Record | Omit Scale Channel Values ** Victoria 3 Support ** - Anna-Marie Source Path Bug fix: ** General Processing ** Record | Omit Delta and Visibility Information Record | Omit Expression readScript Entries
Momcat ( ) posted Mon, 14 July 2003 at 3:05 PM
My theory is because a lot of people use them as character morphs, and using them as part of expression poses could change someone's character.
Spanki ( ) posted Mon, 14 July 2003 at 3:08 PM
Yeah, I figured the same thing... I just always used those for expressions and it's a pain in the ass to have to go hunt them down under Nose morphs or something when I'm trying to create a new expression.
lynnJonathan ( ) posted Mon, 14 July 2003 at 3:30 PM
Thanks everyone. You're all very helpful.
