Thu, Feb 20, 4:33 AM CST
Forum Moderators: Staff
Subject: Can't move a prop origin for Canoma prop
Gromit ( ) posted Wed, 28 June 2000 at 11:19 AM · edited Mon, 17 February 2025 at 12:53 PM
I created a simple prop in Canoma, exported as a Poser prop. In Poser, the prop origin is outside of the figure and when I try to move the origin using the dials, the whole prop translates. Is there some way to edit a file manually to fix this? Gromit
bloodsong ( ) posted Thu, 29 June 2000 at 11:30 AM
heya; i had this happen once in a while, too. dunno why; it's very strange! if the prop is parented to something, try un-parenting it before you move the origin. otherwise, just keep moving the origin (or, rather, moving the object towards the origin) until you get it where it's supposed to be. then just re-position your object.
