Tue, Feb 25, 2:34 PM CST
Forum Moderators: wheatpenny
Photography F.A.Q (Last Updated: 2025 Feb 25 7:08 am)
Subject: Field 1... how to reduce Sun's intensity (if it is too much)?
gallimel ( ) posted Tue, 15 July 2003 at 1:56 AM ยท edited Tue, 25 February 2025 at 2:31 PM
Thank you for any tip on this image... any advice will be appreciated :) 1/3 of underexposure, aprox taken in a sunny day at 6 pm. Available light, Canon IXUS 400
ratto ( ) posted Tue, 15 July 2003 at 6:39 AM
Always the same: is U focus your eye on the grass, this is a perfect shot.. because this is exactly what U see.. if U want to focus on the leaves, then perhaps U should underexpose it a bit.. But I think this is perfect.. I have THIS feeling when I see this light :)
Michelle A. ( ) posted Tue, 15 July 2003 at 6:43 AM
As ratto says the exposure is perfect in this image......
I am, therefore I create.......
--- michelleamarante.com
gallimel ( ) posted Tue, 15 July 2003 at 1:30 PM
thank you to both.. I see it just as a trial shot, but gotta follow your opinion and if you two say is good, then, I am happy and I believe it is :) To get inspired by your own artworks, makes easier to learn how to work with a ccamera believe :)
DHolman ( ) posted Tue, 15 July 2003 at 1:50 PM
Hmm....this would be a tough one. Normally, I'd say split neutral density filter, but having the leaves in the sky portion, don't know what that'd do. Ah, what the heck...I'll still say split neutral density filter with metering for what you want to expose correctly (shadows, mids, or highlights). Of course, there is another solution. Jordy would probably call you a nutter or crazy bloke and tell you to not shoot directly into the sun. :) -=>Donald
gallimel ( ) posted Tue, 15 July 2003 at 1:52 PM
ahaha :) Okay. well, my eyes are too delictae and would see red spots for hours after that ;) I will try to follow your advice at next trial with sunny afternoons then. Guess time comes in just a few days... let's hope for a sunny weekend in Rome :) Ty :) very precious care is yours in takin time to advice me :) It means much and it will be my only way tolearn something for real.Have all a great evening :):)
Rork1973 ( ) posted Tue, 15 July 2003 at 5:53 PM
What I'd do is shoot with a far bigger aperture. Anything further away than a few meters is lacking sharpness. Also, lenses are at their best with handling light when you use their optimal apertures, like between f/8 and f/16. Most lenses have the distance that will be sharp displayed on the aperture ring. That way you can see how far ahead you have to focus your camera in order to get both the leaves in front of you and the trees far away perfectly sharp. So, you've made a very good shot, but your equipment can give you an even better result! :) If you don't know how to do this, you can also try to take several pictures and focus on differnt parts of the shot, and just make them into one sharp shot on your pc :) Anyway, well done!
gallimel ( ) posted Wed, 16 July 2003 at 1:29 AM
thank you very much.. to receive inputs by you, whose tutorials I still cherish and read often, it's the biggest of gifts :) I have also seen that actually my cameraallows the imemdiate collaging in itself... so maybe I can try without PS use to put pieces together:)as well. Ty :9
