Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
As far as I remember lens flares in Vue only apply to light sources. To get a lens flare from light reflected from a surface you would need to place some light sources at or near the reflecting surface to simulate the reflected lights' lens flare. In a similar way, because of the type of rendering Vue uses, if you want to simulate a lighting set up with, for example, a subject lit by a single light source with a refletor used to bounce some light back onto the subject you have to place a light source for the main light source and light sources to represent the reflector. Hope this helps
Thalaxis, it depends what the effect that is desired is: A reflection of a lens flare, which as you say is an internal lens effect and so isn't reflected by surfaces in a scene, is unrealistic. A lens flare from a bright reflection, which does happen in real life because the surface reflected light can cause a lens flare, is realistic.
The lens flare caused by a bloom is still a lens flare. It sounds to me like you're describing two different effects, and using the same name for them. I think that the "hot spot" effect that you are describing is known as a bloom, and the reason that they can generate lens flares is that as far as a camera is concerned, it IS a light source. All it sees is photons, after all :) This does not address the initial post however, which is what my first reply was intended for. That described a different goal from what your suggestion is a solution for.
Terminology may be wrong but effect is the same. What I am seeing is random streaks from highly reflective surfaces such a cars, chrome etc. This could be referred to as "Glitter", "hot spot" or "bloom". It is a natural effect as you can see it with your eyes and don't require a camera (especially around sunset - 1 hr). There is an actual glitter plugin in Lightwave that produces this effect but it looks as though nothing available for Vue.
