Thu, Feb 13, 11:43 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Subject: Poser Problem---animation --please help
Himico ( ) posted Sat, 19 July 2003 at 12:54 PM · edited Thu, 13 February 2025 at 8:49 AM
We were making animation AVI file with sound.
It was working.
Suddenly a problem happened.
This problem happened after we changed the frame rate when we have an imported sound.
Only a few picture frames were produced followed by white blank frames. It was working fine when we were inside of the Pose5.
We tried our previous file without sound. It worked fine.
Once we added a sound to it, again, only a few picture frames, and white blank frames were produced.
Thank you for your help in advance.
HimiCo.
mysticeagle ( ) posted Sat, 19 July 2003 at 1:00 PM
when you change the frame rate after you have made an animation, poser normally tells you that changing the frame rate may effect the output, ive tried re adding,and the sound is always out of sync, but i think the only solution(if you are using mimic change the frame rate in mimic before you save the pose file) is to export the file and then add the sound as a track like you can do in quick time pro, that way u can change the frame rate and try and synch the sound, but im only a newbie...
OS: Windows7 64-bit Processor Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical Processor(s)  6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad day........
Daz Studio Pro 4.5  64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
 link via my artist page
Carrara beta 8.5
My freestuff
markdc ( ) posted Sat, 19 July 2003 at 2:00 PM
I recommending rendering without sound and using an editor like Premiere to add sound later. You should also render to frames (as tif) instead of avi. There are some free editors out there like VirtuaDub, but I haven't used it.
Himico ( ) posted Sun, 20 July 2003 at 12:58 AM
mysticeagle and markdc, thank you very much for your response.
Now, I am thinking to use editor program. As you suggest, I will render frames using poser, and add sound later.
It seems that Premiere is good one, although it is expensive. Probably, I should get it. I need a reliable program.
I don't have Mimic yet. But, I would like to get it in the future.
Is Mimic reliable, and good ?
