Mon, Feb 3, 8:44 AM CST
Subject: Getting Closer to Conformation
RealingDaves ( ) posted Wed, 23 July 2003 at 9:34 AM ยท edited Mon, 03 February 2025 at 6:39 AM
Hi All, Listening to your thoughts about the conforming of the bikini to V3 and i tried applying the bikini to a fresh figure and it fit perfectly but now how do i apply it to the figure i already made without having to re-apply all of her body morphs. THANKS
gildedgecko ( ) posted Wed, 23 July 2003 at 9:39 AM
Did you try the INJ pose approach?
RealingDaves ( ) posted Wed, 23 July 2003 at 9:54 AM
That depends on how you do it?
gildedgecko ( ) posted Wed, 23 July 2003 at 10:08 AM
Attached Link: http://secure.daz3d.com/shop.php?op=itemdetails&item=1225
You conform clothes to V3 AFTER you have her morphs where you want them, so the morphs in the clothes can automatically 'copy' the body morph settings. You can try applying your morphs to the fresh V3 and then re-conforming the already-loaded clothes. I've not ever tried that because I always load clothes after I have V3's morphs where I want them. You need Injection Pose Builder to do what I suggested in the other thread. If you have IPB from DAZ, in Poser, open your T2 file, take out everything but V3, apply the REM pose for All Body Morphs and the REM pose for All Head Morphs, then save the CR2 to your figures library. Then open up IPB and find your figure, make an INJ pose, and save it to a Poser pose folder. Now open a fresh file in Poser, load a fresh V3 and apply the INJ pose you just made. Now load up any V3 conforming clothing and conform to your freshly morphed V3 character. One note even if you don't have Injection Pose Builder: Be sure you have the latest service release version of V3.
Lyrra ( ) posted Wed, 23 July 2003 at 2:40 PM
well if the Bikini has morphs with same name (as transferred by Tailor) then all you need to do is go to V3's 'Body' section, hit copy, then go to the bikinis 'Body' section and hit paste. All the dial info will be copied over. Then reconform just to make sure nothing wandered out of alignment.
gildedgecko ( ) posted Wed, 23 July 2003 at 3:12 PM
Lyrra, Dial settings remain after conforming in P5? I have P4 still, and that's a minor stick in my craw. All dial settings that were there are lost when a clothing item is conformed. I used to have to make MOR poses for my clothes, too, until I figured out another way to do it. :-) I hear good and bad things about P5. I might just have to try it and decide first hand...
Lyrra ( ) posted Wed, 23 July 2003 at 3:53 PM
gecko, I use mostly P4 and I've not had any issues with losing dial settings after conforming. Are you running th patched version?
gildedgecko ( ) posted Wed, 23 July 2003 at 4:36 PM
Yep. But my program has a few software oddities that I've just learned to live with or work around. I've never talked to anyone about this particular oddity before, so I just thought it was a limitation of P4. ;-) That's another one to add to my list :-)
