Fri, Nov 29, 7:37 PM CST
Subject: GROUND TEXTURE
camelot77 ( ) posted Wed, 23 July 2003 at 7:45 PM ยท edited Fri, 29 November 2024 at 5:07 PM
Is therer a way to apply textures to the default ground in poser, I find its easier to use than adding a floor prop, any ideas?
lesbentley ( ) posted Wed, 23 July 2003 at 7:57 PM
In Poser 4 you select the ground, select "Render" from the menu bar, select "Materials", from the Tecture Map section select "Load", and load the texture you want to use.
camelot77 ( ) posted Wed, 23 July 2003 at 8:49 PM
Thanks for your help, in poser 5 I should have known just to go to materials to change it.
