Tue, Nov 26, 9:36 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: MIRROR TEXTURE
camelot77 ( ) posted Wed, 23 July 2003 at 9:55 PM ยท edited Tue, 26 November 2024 at 7:49 AM
How do I create a reflection effect on a texture, if I am using marble as my ground how do I give the marble texture a reflection?
Little_Dragon ( ) posted Wed, 23 July 2003 at 10:27 PM
Poser 4 or Poser 5?
In Poser 5, add a Reflect node to the material's Alt_Diffuse channel, and enable raytracing in your render options.
In Poser 4, you'll probably need to rely on postwork if you want to create a realistic reflection effect.
http://www.renderosity.com/messages.ez?Form.ShowMessage=1149490
SamTherapy ( ) posted Wed, 23 July 2003 at 10:33 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=332856&Start=1&Artist=SamTherapy&ByArtist=Yes
You can do it in P4 without postwork, but it's tricky. You have to do pre-work, by rendering from an exact opposite POV, mapping it onto your surface, then doing your final render. I used a combintation of pre and post work in the image on the end of the link above. Oh yeah, there's nekkid wimmin in the pic, so watch out. :)
