Thu, Dec 26, 2:43 AM CST
Subject: Quick Posing Question
Jlbrown907 ( ) posted Thu, 24 July 2003 at 11:32 AM ยท edited Wed, 25 December 2024 at 1:52 PM
Can pose files be used with any figure? Example, can a pose file (face/body), created using Michael be used on Don/Dork, or vice versa? Thanks
SamTherapy ( ) posted Thu, 24 July 2003 at 11:47 AM
Yes, within limitations. Dork poses work better with Mike than Mike poses with Dork, IMO. That's because Mike has more joints than Dork, so if you use a Mike pose on Dork, you'll be attempting to move body parts that don't exist. That said, you won't destroy anything (except maybe your picture) if you try. You can just about use any pose on any figure but you'll have some weird results at times.
Jlbrown907 ( ) posted Thu, 24 July 2003 at 12:08 PM
Thanks, I appreciate your input!
Patricia ( ) posted Thu, 24 July 2003 at 2:55 PM
I've successfully (to varying degrees ;) used poses pretty freely between all the Mil characters, but haven't tried any for the P4 people on the Mils. (But then, I do tend to use the 'revert to saved' a lot when experimenting like this) Since nearly all poses need tweaking, ones switched between models may only need a little more--in other words, give it a try, but remember to use the Pose Dots as a back-up while tweaking.
Jlbrown907 ( ) posted Fri, 25 July 2003 at 6:41 AM
Thanks Patricia. As stupid as this sounds, I tend to forget about the pose dots!!! I mostly save and revert when I experiment. Thanks again.
