Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 05 8:02 am)
Only $7.96 for a limited time! If you're like most Poser users, you probably have dozens of zip files that you've downloaded but have yet to install. With PInstall you can create a blank runtime (P5)and install them all there at once. Then you can check them out in P5 to see which ones you want to put in your main library.
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=7054
PInstall - the fast and easy way to install Poser library files.What is PInstall?
PInstall is a standalone application which allows you to install poser library objects (characters, poses, textures, etc) without needing to figure out which files go in which Poser subdirectory--PInstall does it for you. You don't even have to unzip library files stored in zip archives. Also, you can use PInstall to unzip and install a variable number of archives automatically!
Latest features (2.0):
Support for Poser 5 hierarchical folders (multiple subfolders).
Support for new Poser 5 types.
Function to create blank runtimes (Poser 5 supports multiple runtimes).
Includes: Multi-unzip utility
This utility allows you to unzip any number of zip files to a directory of your choosing without placing files in the Poser library structure. You can use this utility for mp3s, images, max or any other files that you download from the internet
