Mon, Dec 23, 3:04 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Subject: Atomic Views
Gelana ( ) posted Sun, 27 July 2003 at 11:23 PM ยท edited Wed, 13 November 2024 at 4:08 AM
I was wondering if there were any DLs that would allow me to make a still that had the Character look like they were being surounded by electrons. You know like the Nuclei of an atom is surounded by spinning electrons. Just make the Nuclei the Character. Thanks Gel
Gelana
PaganAttitudes.com
EricofSD ( ) posted Mon, 28 July 2003 at 1:08 AM
Not sure what you are looking for, but there is an electron microscope texture/technique by Adamite that you can use in Bryce. Agent Smith linked to the files in the Bryce forum so check that out.
Little_Dragon ( ) posted Mon, 28 July 2003 at 4:38 AM
Something like this?
Just use a group of torus props and increase their transparency. Add spheres to the tori to emphasize electrons, if necessary.
Gelana ( ) posted Mon, 28 July 2003 at 7:00 AM
Little Dragon, that is what I am looking for but you might as well be speaking greek. I am also using Poser v4. can it even do that? What is a torus??? Gel
Gelana
PaganAttitudes.com
cruzan ( ) posted Mon, 28 July 2003 at 8:04 AM
Torus is Under Props - Prop Types and you should use a render of your character as texture map and a transparancy map of that render. To make a transparancy map to match your render - i use the Display - silouette - then export image (no render). Then I take it to a paint program (use psp or photoshop) blacken out transparent area and truely whiten visible areas to create the transparent material.
Lyrra ( ) posted Mon, 28 July 2003 at 11:18 AM
torus = donut shape
