To be technical, neither V3 Blank nor V3 regular have the deltas you are after -(except for the JCM and eye morphs). If the deltas were already in the file, there would be no need to inject them. The point of using IPB is to generate a file that only injects the needed morphs into V3 regular. V3 regular has the slots/channels to host the injected deltas. V3 Blank does not. All a slot is = the morph channel name and a pair of brackets to hold the morph when it is injected. But unless the slot is there -for every morph, an injection pose file has nothing to "talk to". V3 Blank is handy for generating regular poses and as a host for content producers to use. It is not really all that good as a place to host single morph characters. Characters need expressions and there are function morphs like hide nipples and shoe fit that may be needed. V3 Blank has no provision for these.
I created a model based on Vic3 and used Injection Pose Builder as directed. I loaded V3 blank and added my new pose to it. The dials that I used for the new model did show up after I loaded the pose but the V3 blank figure did not change and the dials were not set at all. I don't understand. Am I using the Injection Pose Builder correctly and shouldn't the V3 blank have morphed into my new model?
