Tue, Feb 11, 4:06 AM CST
Subject: I am begging for some help
therealpackman ( ) posted Thu, 31 July 2003 at 8:11 PM ยท edited Mon, 10 February 2025 at 10:09 PM
I recently purchased Victoria3 and the head and body morph paks... I use Poser4. I followed the indtructions from DAZ that came when i bought these, but I'm having no luck with loading any of the Victoria poses or expressions.... I can pose the figure with my standard poses and my downloaded poses, but the skin and face stay in the default mode. If there is someone who understands all this and can help, I would be forever in debted to you. I tried e-mailing tech support at DAZ, but have not gotten a reply as yet. I guess what I'm asking is for a step by step tutorial to create a rendering with V3 including eyebrows and eyelashes and all those goodies...lol
My e-mail address is packman9810@aol.com if someone can help
Thanks
MachineClaw ( ) posted Thu, 31 July 2003 at 8:20 PM
make sure you head over to Daz and check for the updates to all the packs that you bought. there were intial problems with the release of V3, though if you bought recently those should be fixed, but just to be on the safe side. Make sure you are loading the V3 base model and not V2/V3 which is a differnet model (I did this so much I had to move the links so I would quite screwing myself up). if you are injecting a morph (with a +) it may take some time depending on your system, memory etc. when you installed V3 and the packs did you move the installed files? did you install to your root runtime folder? morph injections are picky and need to be installed to the runtime folder (least the !Daz one does, maybe more).
therealpackman ( ) posted Thu, 31 July 2003 at 8:27 PM
I am not really really computer savvy... What I did was simply load the items according to the instructions provided from DAZ. everything works the way it is supposed to up until I try to load a morph...... then I get the error........ Warning : cannot open runtimelibrariespose3 full body(whichever morph i select)
bull57 ( ) posted Fri, 01 August 2003 at 11:09 AM
In your runtime folder there should be a(NEW) folder called:!DAZ the v3 stuff should be in there in separate folders, maybe you misplacced it!
RHaseltine ( ) posted Fri, 01 August 2003 at 1:34 PM
If it is looking in the Pose library for the injection script you must have the old version somehow. It needs updating to 1.1.
