It looks like you are saving as a JPG. Never do that except for sample renders, and then use the high quality setting. I almost always save as a PSD. PSD is Photoshop format. It saves the alpha channel (transparency information), and it is compatable with most image editing, and graphic paint programs. You can't put it right on the web like that though. You'll have top take it into a graphics program and resave it in a web format. But then you'll have more control over the quality, and have the option of doing post work on it if you want to.
This raises a question in my mind. ("Where else do I raise questions?" you ask, "Mind your own business" I reply). When you render a movie, you get a choice at to the quality of JPG you want to save, but I don't remember seeing this option when you save a single render. What determines the quality level of a single render save?
Thanks guys, I just found what the problem was. Brain dead I guess from too much work and trying to do something late at night. I forgot all about the quality settings on the save screen. It does default to the lowest setting and for reasons unknown to me and probably anyone else, I neglected to change that setting to high quality. Thanks for the tips guys. Just read this message after I checked what I was doing when saving an image and you were right about the quality settings on the save screen. Cherokee
alternate... adjust the pixel sample slider up to 12 then...that'll increase the quality of the render much more.but I would advice that you use the poser 4 engine and just do some postwork on photoshop...it's a lot safer and faster. takes he'll alot of time to render a dynamic hair and full scened, textured, proped image. I tried making a seraphim...6 wings and all, no clothes, tatooed skin tex, a sword...took me 23 hrs...it was only 75% completed then so I just pulled the plug on the %(&%* and used the poser 4 renderer.
If rendering to the internal window, I think you have to use export image instead, this will not save it as a pz3 I think. Somtimes, when saving an image from an external window sometimes poser 5 hides the save window behind the image and I have to click on the program in the windows open applications bar and this brings it around and I can save the image and continue working. This also works for me when poser hangs sometimes. Just something I noticed.
